Re: Plymouth Duster. Which forward scoop Actually Works ?
[Re: FIREGUY12]
#1161379
01/20/12 04:08 PM
01/20/12 04:08 PM
Posts: 554 Kentucky
clovis
Kentucky
I think my steel hood on my '75 is 62lbs and that is with a little bracing removed and a 11" x 18" hole cut in it. Going through the same dilemia now with the scoop selection. I have researched until I am tired of thinking about it. The conclusion I have come to is that what works on one may not necessarily work on another. How the air flows over the front the car is a big factor in catching the "good air" with a forward facing scoop. Which means the shape, rake and mph all play a factor. Then you combine that with sealing or no sealing, filter or no filter, air bell or...ok I am going to stop now.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: FIREGUY12]
#1161380
01/20/12 04:09 PM
01/20/12 04:09 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
How fast in MPH does your car run now? I have raced two cars with a six pak scoop and a SS/AA Hemi scoop, both try to pull the hood off above 125 MPH My Duster has the SS/AA Hemi scoop on it, it is constantly trying to rip the front edge Dzuz fasteners off that hold the hood in the front, there are four of them. The two side ones attach to the fenders and the two middle ones attach to the radiator support I have four in the front, two on each side along with the stock hood hinges(springs removed) and two in the middle on the back side behind the scoop. My scoop is a NHRA legal 1968 SS/AA scoop, not the raised version thta is popular today in bracket racing.
[Re: Coldart]
#1161387
01/20/12 06:34 PM
01/20/12 06:34 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
draw a line from the top front edge of the hood to the top of the windshield.. the scoup would need to be higher than that line to actually catch air.. fwiw.. Don Carlton did alot of testing on that..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: FIREGUY12]
#1161389
01/20/12 06:44 PM
01/20/12 06:44 PM
Posts: 1,505 TN
SCATPACK 1
TN
Dang that is a good looking Duster. Post some more pics of the suspension and engine
Old Geezer Racing
[Re: HEMIFRED]
#1161392
01/20/12 07:35 PM
01/20/12 07:35 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Mine is a aero style too but doesn't really get in my line of view.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Al_Alguire]
#1161393
01/20/12 08:08 PM
01/20/12 08:08 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
I believe it is this one http://www.rjracecars.com/RJF13-Sportsman-Hoodscoop-RJF13-Prodview.htmlBut Chris will know for sure. I do not recall. As for visibility running S/St. I dont have any problems with mine in S/ST. But then again I dont have anyone chasing me either
