Plymouth Duster. Which forward scoop Actually Works ? #1161377
01/20/12 02:04 PM
01/20/12 02:04 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Looking to buy a hood for my duster and go to a forward facing hood scoop. To drop some noise weight off as I currently have a steel hood. Would like to know how much weight lose and which forward scoop works best a still looks goods. All input in greatly appreciated. thanks moparts.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: FIREGUY12] #1161378
01/20/12 04:06 PM
01/20/12 04:06 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
Come on moparts. ?
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: FIREGUY12] #1161379
01/20/12 04:08 PM
01/20/12 04:08 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
I think my steel hood on my '75 is 62lbs and that is with a little bracing removed and a 11" x 18" hole cut in it. Going through the same dilemia now with the scoop selection. I have researched until I am tired of thinking about it. The conclusion I have come to is that what works on one may not necessarily work on another. How the air flows over the front the car is a big factor in catching the "good air" with a forward facing scoop. Which means the shape, rake and mph all play a factor. Then you combine that with sealing or no sealing, filter or no filter, air bell or...ok I am going to stop now.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: FIREGUY12] #1161380
01/20/12 04:09 PM
01/20/12 04:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
How fast in MPH does your car run now? I have raced two cars with a six pak scoop and a SS/AA Hemi scoop, both try to pull the hood off above 125 MPH My Duster has the SS/AA Hemi scoop on it, it is constantly trying to rip the front edge Dzuz fasteners off that hold the hood in the front, there are four of them. The two side ones attach to the fenders and the two middle ones attach to the radiator support I have four in the front, two on each side along with the stock hood hinges(springs removed) and two in the middle on the back side behind the scoop. My scoop is a NHRA legal 1968 SS/AA scoop, not the raised version thta is popular today in bracket racing.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: FIREGUY12] #1161381
01/20/12 04:17 PM
01/20/12 04:17 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
5 1/2 tall VFN scoop molded on my old MAZ hood
1.39 9.85 - 137 mph
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: Cab_Burge] #1161382
01/20/12 04:22 PM
01/20/12 04:22 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
I run 131mph. with plans of going faster. So does anyone have any pics. i was considering the 5 inch six pack or hemi scoop. My steel hood trys to pull of with pins in the front on stock hinges.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: FIREGUY12] #1161383
01/20/12 05:03 PM
01/20/12 05:03 PM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
I have a 5" six pak on mine, been 160+ stock hinges and hood pins.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: 572_HEMI_Cuda] #1161384
01/20/12 05:18 PM
01/20/12 05:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well if you want a truly FUNCTIONAL scoop you need one that allows for enough room above the carbs to work. IMO for a racecar get a racecar scoop.
Not a great picture but something like these if you want a functional piece.
Or this although we have not sealed it yet.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: Al_Alguire] #1161385
01/20/12 06:03 PM
01/20/12 06:03 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
What brand scoop on the black car. thats what i want. would like to see a side view. i run super street so i need something with good visibility.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: FIREGUY12] #1161386
01/20/12 06:17 PM
01/20/12 06:17 PM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
AAR fiberglass has newer style scoop.
Can change length and width.
I just like the quality of their stuff.
Anything that gets the opening off the hood surface.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: Coldart] #1161387
01/20/12 06:34 PM
01/20/12 06:34 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
draw a line from the top front edge of the hood to the top of the windshield..
the scoup would need to be higher than that line to actually catch air..
fwiw..
Don Carlton did alot of testing on that..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: Coldart] #1161388
01/20/12 06:36 PM
01/20/12 06:36 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Mine is an aero style. I cut it down from its original height. Its still too tall as it leaves a blind spot.I believe it works well though. I think it has 10 dzus fasteners. I believe for a scoop to work properly like Al said the carb shouldnt be too close to the top of the scoop and it needs to be sealed to the scoop.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: FIREGUY12] #1161389
01/20/12 06:44 PM
01/20/12 06:44 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Dang that is a good looking Duster. Post some more pics of the suspension and engine
Old Geezer Racing
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: SCATPACK 1] #1161390
01/20/12 06:52 PM
01/20/12 06:52 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Thanks, Engine & scoop sealer.Sorry for the poor picture.
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: DavidDean] #1161391
01/20/12 07:14 PM
01/20/12 07:14 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
the direct connection testing
home of the
Sox and Martin Hemi Duster
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: HEMIFRED] #1161392
01/20/12 07:35 PM
01/20/12 07:35 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Mine is a aero style too but doesn't really get in my line of view.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Plymouth Duster. Which forward scoop Actually Works ? [Re: Al_Alguire] #1161393
01/20/12 08:08 PM
01/20/12 08:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I believe it is this one
http://www.rjracecars.com/RJF13-Sportsman-Hoodscoop-RJF13-Prodview.html
But Chris will know for sure. I do not recall.
As for visibility running S/St. I dont have any problems with mine in S/ST. But then again I dont have anyone chasing me either
