5.7 tech help... error code P0403 #116032
09/06/08 01:59 PM
09/06/08 01:59 PM
Wisconsin
Garceau Offline OP
Garceau  Offline OP
Wisconsin
OK I know its the EGR circuit.
I popped the EGR valve off and it looks pretty clean. No major build ups, but I cleaned it anyways. No chunks came out and all seemed good. Blew air through it and again everything was clean. Pulled the air tube off and cleaned that as well, no blockage or anything else.
Disconnected battery and reinstalled, check engine light still on. Still getting same code p0403
Everything I know says the EGR valve itself rarely goes out. Usually just a carbon build up, but doesnt seem to be the case here.
Any help, info...... 2005 dodge ram 1500 5.7
Re: 5.7 tech help... error code P0403 [Re: Garceau] #116033
09/06/08 02:25 PM
09/06/08 02:25 PM
Mopar sells 1079 5.7l EGR valves a week...
I believe the techs usually say position sensor is bad not the actual valve. At 66 dollars list
for 53032509am go get 1. Don't forget little pipe gasket 5277928 for like 2.50.
Re: 5.7 tech help... error code P0403 [Re: Garceau] #116034
09/06/08 03:16 PM
09/06/08 03:16 PM
I did a quick search for any TSB's or flashes but didn't find any. P0403 is a solenoid circuit code not a sensor code. The diag for the code bassicaly has you check the circuit's beween the valve and the PCM. If the circuits are good then it's likely a problem with the valve or it could be the drivers in the PCM. This is where the DRB or the starscan would come in handy because you could actuate the valve with the scanner and see if the valve opens. You best bet is to disconect the connector at the valve, and the PCM and measure the db/vt wire which is the solenoid controll wire for any shots to ground or voltage or opens with a DVOM and measure the resistance of the ground circuit (the bk/wt wire) to a good ground ( should be very little resistance) If the circuit's are good then replace the valve. Like I say, it could be the PCM but it's probably the valve.
Re: 5.7 tech help... error code P0403 #116035
09/06/08 03:49 PM
09/06/08 03:49 PM
Wisconsin
Garceau Offline OP
Garceau  Offline OP
Wisconsin
Well at that price I will just pick one up. Its like a 15 minute job to change, will give it a shot then. If light still comes on, I will have to take it in and get it scanned I guess. But for 60 bucks and an hour of my time its worth a shot.
I had no idea what the price was, I tried getting one already today but service at local dealership is closed already
Re: 5.7 tech help... error code P0403 [Re: Garceau] #116036
09/09/08 01:06 PM
09/09/08 01:06 PM
MS/TX
SHEPP Offline
SHEPP  Offline
MS/TX
I just finish dealing with the same thing on my 05/ram 1500/5.7 I just bought a new one after hearing everyone elses story and did like most; replace it since its cheap and an easy install; then clean the old one and save until you need another. the code will go away once the new one is installed after a few cycles or just reset the computer.
Re: 5.7 tech help... error code P0403 [Re: SHEPP] #116037
09/09/08 01:17 PM
09/09/08 01:17 PM
Columbus Ga
reflections7 Offline
Columbus Ga
Rock auto has them for 33.00 I just ordered one for my father in laws 04 ram 5.7
