Which ATI damper for 440 stock timing cover? #1160284
01/18/12 05:30 PM
01/18/12 05:30 PM
Raleigh, NC
Meangreen68 Offline OP
Raleigh, NC
I'm looking at ATI's damper page and they list two dampers for the stock timing cover, part# 917471E and 917470E.
I'll be using my stock pulleys.
Which one do I buy?
Thanks, John
Re: Which ATI damper for 440 stock timing cover? [Re: Meangreen68] #1160285
01/18/12 05:36 PM
01/18/12 05:36 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't think stock pulleys will work with any of the ATI dampers?
Re: Which ATI damper for 440 stock timing cover? [Re: 451Mopar] #1160286
01/18/12 07:22 PM
01/18/12 07:22 PM
Raleigh, NC
Raleigh, NC
I just made the call to ATI's tech line just before closing at 5pm.
Part# 917470E is used with the stock OEM timing cover and pulleys.
Hopefully, that means the alignment with the other pulleys is maintained and not just the bolt circle.
Re: Which ATI damper for 440 stock timing cover? [Re: Meangreen68] #1160287
01/18/12 07:55 PM
01/18/12 07:55 PM
Over the years they have made a pile of different versions --Maybe ask Kenny at Indy ( i know....)
We used to make a shim that went on crank snout to space ATI's out to fit Indy covers--the ID of the damper from them will need some honing to fit your crank --measure both and fix--they say tight is good but so tight it will not go on or welds itself on after brutal install is TOO tight--measure before you start to put it on--
Re: Which ATI damper for 440 stock timing cover? [Re: Meangreen68] #1160288
01/18/12 07:58 PM
01/18/12 07:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That is the correct part #. It will work but I did need to use a .060" shim for the WP pulley and some shimming of the alt as well. You will also need to modify the timing tab as well to be able to get a good read on the balancer.
Re: Which ATI damper for 440 stock timing cover? [Re: BSB67] #1160289
01/18/12 08:06 PM
01/18/12 08:06 PM
Raleigh, NC
Raleigh, NC
That's what I'm after. Thanks.
Re: Which ATI damper for 440 stock timing cover? [Re: BSB67] #1160290
01/24/12 12:07 AM
01/24/12 12:07 AM
Raleigh, NC
Raleigh, NC
Hey BSB67,
The damper came in today. It came in two parts.
Do the numbers on the parts look correct?
...parts like this can keep one on a beans & rice diet for a while.
Re: Which ATI damper for 440 stock timing cover? [Re: Meangreen68] #1160291
01/24/12 08:11 AM
01/24/12 08:11 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes, but you have a quality piece that you don't have to worry about.
The damper assy is 917470, shell 7040, and hub 6661.
