Rough running issues on a 318 2 bbl
#1160129
01/18/12 10:14 AM
01/18/12 10:14 AM
Posts: 86 Ontario
Mopar Boy
Ontario
Been working on getting the 318 in the 68 Newport tuned up. Having issues with it running. Unless you baby the throttle the motor dies. If you also give it more than 60%, it bogs.
I have changes the cap, rotor, plugs, wires, and set the timing at 8 deg, new air filter and a bunch of other items that are not really related.
Question is, where do I go from here? I seem to have good spark, so I would assume fuel. Also, as the carb was apparently rebuilt this past summer prior to my owning it, I wonder if the internals are screwed.
Thoughts?
Thanks,
Robert
1969 Chrysler 300 440/727 1980 W350 Crew Cab Dually with 1997 12V Cummins & many, many goodies 1990 W250 Cummins NV5600
Re: Rough running issues on a 318 2 bbl
[Re: Mopar Boy]
#1160130
01/18/12 10:33 AM
01/18/12 10:33 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
From your description it sounds like the accelerator pump has dried out or incorrectly adjusted.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#1160131
01/18/12 10:40 AM
01/18/12 10:40 AM
Posts: 15,487 Florida
scratchnfotraction
Tim
BBD 2-v carbs are that way.
[Re: Mopar Boy]
#1160133
01/18/12 10:48 AM
01/18/12 10:48 AM
RapidRobert
As said carb & need more than 8 deg initial. check A/P then float level & shoot a 2 second blast of starting fluid in each idle mixture screw hole, vac leak
[Re: RapidRobert]
#1160134
01/19/12 08:51 PM
01/19/12 08:51 PM
Posts: 86 Ontario
Mopar Boy
Ontario
Thanks for the advice guys! Says what I hoped was not true! LOL
[Re: Mopar Boy]
#1160135
01/19/12 08:58 PM
01/19/12 08:58 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I was just curious why some one would put a 318 in a 68 NewPort? Seems like a lot of work to go to a small block in a car that never had one. Or was it a 383? Either way those carter 2bbl bbd carbs are a breeze to rebuild.
I have mechanical Aptitude. I can screw up anything.
[Re: 268RTs4ME]
#1160136
01/19/12 11:03 PM
01/19/12 11:03 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Time to take the carb off and rebuild it, also make sure you put in a new float. The caskets and new pump should be in the kit.
There's no need to put in a new float unless the one in there is shown to have a leak. The float in mine was perfectly fine, and it was rebuilt (poorly) at least once before with the float level set all wrong.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: scratchnfotraction]
#1160138
01/20/12 07:51 AM
01/20/12 07:51 AM
Posts: 27,728 places
79powerwagon
places
Tim
I HATE BBD carbs. Of all of them that I've had over the decades, only ONE of them worked properly, and no amount of rebuilding will correct anything on them!
There was someone, this past summer, selling brand new ones. You'd be way ahead doing this, and even further ahead if you found a 2v Stromberg instead. Of course, 4v is the real ticket, but if you insist on 2v, the Stromberg is a better Mopar carb.
To the poster stating no small blocks in C bodies- you sir, are wrong. Maybe not originally in THAT particular model and year, but there are PLENTY of small block and /6 C bodies made!
[Re: 79powerwagon]
#1160139
01/20/12 12:36 PM
01/20/12 12:36 PM
Posts: 86 Ontario
Mopar Boy
Ontario
No, it is a 318/904. It was a 383/727 though. Why change it to a small block? Beyond my comprehention as to why they would go through the hassle! Not to mention the casting date says 1985!? It did allow me to get a decent deal on it though! Either way, I want to stay 2 barrel for the time being as the motor wont be in there for more than a year. Just have to save up some more funds and then it will go under the knife after the parts have been collected. If I go to a 4 barrel, then I need to get intake pan, manifold, etc. For where I am going, makes more sense to just get it driveable for the least amount. I have also gone down this new carb road. Makes the most sense. Where would I buy a new one and how much CFM do I need for a stock 318? I was looking on Summit and found these. Would either work? Or is there a better one I should consider? http://www.summitracing.com/parts/HLY-64-1183/http://www.summitracing.com/parts/HLY-64-1169/Thanks,
[Re: Mopar Boy]
#1160141
01/20/12 12:52 PM
01/20/12 12:52 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
For the price of a kit, the BBD is one of the easiest carbs to rebuild ! Think you would be money ahead doing that, over buying another one that may or may not be any better than the one you have.
I have always found, especially with stock motors, that if you rebuild it according to the factory instructions (or those included with the kit), you usually end up with something very very close to perfect for your application.
Have done that with Thermoquads over the years too . . . always had em work great !! With a bit of time, and reading (go figure - read the instructions !!), you should be able to get the carb you have on the car now, running like a top !!
Why take a big block drivetrain out of a C body and replace it with a small block drivetrain ? Come on, you get the big block for another project, and still have a running/driving C body ! . . . bought a 69 Chrysler 300 like that . . . it did get the 440 later on though !!
Hope it works out for you . . .
Cheers
Mark
[Re: Dean_Kuzluzski]
#1160143
01/20/12 03:26 PM
01/20/12 03:26 PM
Secret Chimp
Eugene, Oregon
If you're still scratching your head over this, you can have the BBD off of my Coronet when I'm done with my four barrel swap in a couple of weeks. It's a non-emissions carb so it has none of the junk that made them pains in the butt. Always works perfectly for me.
[Re: dOrk !]
#1160146
02/03/12 10:30 AM
02/03/12 10:30 AM
Posts: 86 Ontario
Mopar Boy
Ontario
OK. I have battled over the last few weeks what I want to do. I ended up deciding to just wait and collect some funds, and do it right. Put on a 4 barrel and call it a day. If I am going to do it, may as well do it right.
Thanks for all of the input folks. Again, you have all kept me on the right course!
[Re: Mopar Boy]
#1160148
02/03/12 11:59 AM
02/03/12 11:59 AM
RapidRobert
dont forget to bump that initial up!
