What's the secret to changing a SB oil filter w/headers
#1159776
01/17/12 10:52 PM
01/17/12 10:52 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
... and not making a huge mess!?!?! I've had to change the oil filter a few times on my Road Runner, and despite my best efforts, every time I've finished the project with a bunch of degreaser and a garden hose. I've got TTi headers and a short filter. No 90 degree adapter. Just not enough room to work down there to put any sort of deflector, or to wrap the headers. I've tried just about everything short of installing a remote filter. I've been a big block guy for a long time. I'm used to just trying to keep it off the K-frame. It's an easy clean-up.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: What's the secret to changing a SB oil filter w/headers
[Re: 471Magnum]
#1159777
01/17/12 10:56 PM
01/17/12 10:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
wrap the header in aluminum foil, change filter, let mess drain, remove foil.
[Re: Supercuda]
#1159778
01/17/12 11:05 PM
01/17/12 11:05 PM
Posts: 15,487 Florida
scratchnfotraction
[Re: scratchnfotraction]
#1159779
01/17/12 11:10 PM
01/17/12 11:10 PM
471Magnum
Space Station #5
I've tried the foil before. Guess I need some heavier stuff because what I borrowed from the wife's kitchen would tear when I tried to wrap.
-Jim
#1159781
01/17/12 11:37 PM
01/17/12 11:37 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Sharpen a steel rod to use as a punch.. Punch a hole in the filter & drain it before you unscrew it.. I use a piece of a plastic bottle to direct the oil were I want it to go... Then as you unscrew the filter drop it directly into a ziplock bag...
[Re: bigblock340power]
#1159788
01/18/12 12:11 PM
01/18/12 12:11 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
I cut a hunk of cardboard big enough to make a "roof" over the part of the header to be dripped on and a drip pan. Oil drips on cardboard, flows to the pan, and stayes off header. Works great!
That's exactly what I do as well, jam the cardboard under the filter against the block. I wrap aluminum foil around the tubes 1st as a precaution.
[Re: Pntastar69]
#1159789
01/18/12 04:35 PM
01/18/12 04:35 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I use a small (low profile) plastic bowl that sits on top of the header (below the oil filter) to catch the oil. Works great, no oil on the header pipes.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
#1159790
01/18/12 06:23 PM
01/18/12 06:23 PM
Posts: 1,012 indiana
mcmopars
indiana
try it with a set of hot headers
cold is fine just takes a little longer to drain
yea tell me about it.those tti headers are not cheep,nothing like oil on a hot ceramic header.didnt take me long to learn to do it cold
