What's the secret to changing a SB oil filter w/headers #1159776
01/17/12 10:52 PM
01/17/12 10:52 PM
Space Station #5
471Magnum Offline OP
Space Station #5
... and not making a huge mess!?!?!
I've had to change the oil filter a few times on my Road Runner, and despite my best efforts, every time I've finished the project with a bunch of degreaser and a garden hose.
I've got TTi headers and a short filter. No 90 degree adapter.
Just not enough room to work down there to put any sort of deflector, or to wrap the headers. I've tried just about everything short of installing a remote filter.
I've been a big block guy for a long time. I'm used to just trying to keep it off the K-frame. It's an easy clean-up.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: What's the secret to changing a SB oil filter w/headers [Re: 471Magnum] #1159777
01/17/12 10:56 PM
01/17/12 10:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
wrap the header in aluminum foil, change filter, let mess drain, remove foil.
Don't be the exception.
Re: What's the secret to changing a SB oil filter w/headers [Re: Supercuda] #1159778
01/17/12 11:05 PM
01/17/12 11:05 PM
scratchnfotraction Offline
Re: What's the secret to changing a SB oil filter w/headers [Re: scratchnfotraction] #1159779
01/17/12 11:10 PM
01/17/12 11:10 PM
Space Station #5
Space Station #5
I've tried the foil before. Guess I need some heavier stuff because what I borrowed from the wife's kitchen would tear when I tried to wrap.
-Jim
Re: What's the secret to changing a SB oil filter w/headers [Re: 471Magnum] #1159780
01/17/12 11:13 PM
01/17/12 11:13 PM
I use a filter with no anti drain back valve and remove the filter after sitting over night.
the filter does not spill oil that way.unless I tilt the filter to much anyways.
Re: What's the secret to changing a SB oil filter w/headers [Re: scratchnfotraction] #1159781
01/17/12 11:37 PM
01/17/12 11:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Sharpen a steel rod to use as a punch.. Punch a hole in the filter & drain it before you unscrew it.. I use a piece of a plastic bottle to direct the oil were I want it to go... Then as you unscrew the filter drop it directly into a ziplock bag...
Re: What's the secret to changing a SB oil filter w/headers [Re: 1_WILD_RT] #1159782
01/18/12 01:22 AM
01/18/12 01:22 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I let the car sit for 24 hours and then remove the fiter. No oil drains from the attaching fitting on the block.
Raul
Re: What's the secret to changing a SB oil filter w/headers [Re: 471Magnum] #1159783
01/18/12 04:29 AM
01/18/12 04:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I used to have a Trans-dapt remote filter (dual filters) on my 360 powered truck. It just moved the oil mess from the block/headers to the fender where the filters were mounted.
Re: What's the secret to changing a SB oil filter w/headers [Re: 451Mopar] #1159784
01/18/12 06:32 AM
01/18/12 06:32 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I just loosen the filter, place a plastic bag over the filter and loosen it by hand from outside the bag, and let the residual oil fill inside the bag with the filter, after a few seconds it's drainded...easy
Re: What's the secret to changing a SB oil filter w/headers [Re: scratchnfotraction] #1159785
01/18/12 07:24 AM
01/18/12 07:24 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
sucks having to change oil on a cold engine.
Re: What's the secret to changing a SB oil filter w/headers [Re: mcmopars] #1159786
01/18/12 10:38 AM
01/18/12 10:38 AM
try it with a set of hot headers
cold is fine just takes a little longer to drain
Re: What's the secret to changing a SB oil filter w/headers [Re: scratchnfotraction] #1159787
01/18/12 10:56 AM
01/18/12 10:56 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I cut a hunk of cardboard big enough to make a "roof" over the part of the header to be dripped on and a drip pan. Oil drips on cardboard, flows to the pan, and stayes off header. Works great!
Re: What's the secret to changing a SB oil filter w/headers [Re: bigblock340power] #1159788
01/18/12 12:11 PM
01/18/12 12:11 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
That's exactly what I do as well, jam the cardboard under the filter against the block. I wrap aluminum foil around the tubes 1st as a precaution.
Re: What's the secret to changing a SB oil filter w/headers [Re: Pntastar69] #1159789
01/18/12 04:35 PM
01/18/12 04:35 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
I use a small (low profile) plastic bowl that sits on top of the header (below the oil filter) to catch the oil. Works great, no oil on the header pipes.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: What's the secret to changing a SB oil filter w/headers [Re: scratchnfotraction] #1159790
01/18/12 06:23 PM
01/18/12 06:23 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
yea tell me about it.those tti headers are not cheep,nothing like oil on a hot ceramic header.didnt take me long to learn to do it cold
Re: What's the secret to changing a SB oil filter w/headers [Re: mcmopars] #1159791
01/18/12 08:10 PM
01/18/12 08:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, either catch the oil above the headers or cover the tubes and direct it. On my BB & Hemi motors, I use those cheap foil baking pans and bend them so they go a bit behind the filter and direct the oil to my drain pan.
Re: What's the secret to changing a SB oil filter w/headers [Re: topside] #1159792
01/19/12 04:01 PM
01/19/12 04:01 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
my secret is that i have officialy given up and let it be the mess it realy is.
Re: What's the secret to changing a SB oil filter w/headers [Re: 1Fast340] #1159793
01/19/12 06:10 PM
01/19/12 06:10 PM
P
Paul_Fancsali Offline
P
On cold engine I place a oil catch mat on the headers to get the oil. I got some that soak up oil without the mess. Also a 90 degree will solve most of the mess
