572 Hemi - Mopar X Ram setup tips #1159605
01/17/12 08:40 PM
01/17/12 08:40 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Guys...need some advice on jetting a 572 Hemi with a MP X ram intake and duall 770 cfm Holleys. Appn is street/strip.
Engine combo is :
572 Hemi - pump gas
Bryant Crank, Saenz steel rods
Diamond slugs 11:1 CR net
Indy heads 425cfm @ 700"
Bullet roller 265 @ .050" mid - high 600's lift
Mopar X ram with dual 770's
2.25" headers
Car weight 3450lbs
Im wondering what jetting/sec springs will be in the ballpark to run for inital setup before track tuning?
Also, has anyone run 1" phenolic 4 hole spacers under these carbs with good results on this intake ? I have the space to use them and not sure if they will help or not. Curious more than anything....
Any info would be much appreciated thanx fellas !
Re: 572 Hemi - Mopar X Ram setup tips [Re: LAD 524] #1159606
01/17/12 09:27 PM
01/17/12 09:27 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Interesting question
Here is a bump. Hopefully someone with experience with a cross Ram will chime in.
Are you using factory carbs or two standard single carbs? If replacements, what are you using for linkage?
Old Geezer Racing
Re: 572 Hemi - Mopar X Ram setup tips [Re: SCATPACK 1] #1159607
01/17/12 09:45 PM
01/17/12 09:45 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey there...carbs are the new Holley repro 770 cfm vac sec - identical to the originals. Linkage is A&A style.
BTT
Re: 572 Hemi - Mopar X Ram setup tips [Re: LAD 524] #1159608
01/17/12 10:47 PM
01/17/12 10:47 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
on the dyno my 12:1 477 made more power when we ditched the staggered screw in jets and put 78's in all (these were bone stock carbs with untouched metering plates)the primary sides.
Re: 572 Hemi - Mopar X Ram setup tips [Re: prochargedhemi] #1159609
01/18/12 06:42 PM
01/18/12 06:42 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thx....anyone else?
Re: 572 Hemi - Mopar X Ram setup tips [Re: LAD 524] #1159610
01/19/12 12:28 PM
01/19/12 12:28 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
For the street they are not bad out of the box. I run 80 jets in mine. My inner genious told me to fiddle with my carbs and by the time I was done it would hardly run (go figure). I sent them off to Barton for the SS prep, well worth it.
