Hopefully my last 6 pack question
#1159512
01/17/12 05:46 PM
01/17/12 05:46 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Ok, so Im rebuilding the center carb, first of all, the metering block to bowl gasket is not the same, close, but not perfect, second, these carbs were dirty carbs when I got them, and the metering block gasket is missing and I have nothing to compare that gasket to. What is the correct gasket for this carb? I cand read the directions, the print is VERY small, and blurry as hell. basically there is 3 gaskets to choose from, a black one, and 2 blue ones. 1 blue one has a cut out for the squirter hole in the carb body, I dont think thats the correct one as it will not seal to the hole on the metering block, the 3rd one has the squirter hole in it, but looks like the black one, but is missing 1 little hole up by the rectangle center hole.
Pretty damn confusing for a simple carb.
Kasey
Re: Hopefully my last 6 pack question
[Re: Moparnut426]
#1159513
01/17/12 06:14 PM
01/17/12 06:14 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
Holley 2300's? Here's the kit for them:
Holley # 3-396
How are things in NE?
dstryr, since 1986.
[Re: screamindriver]
#1159523
01/17/12 08:07 PM
01/17/12 08:07 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I don't have the metering block numbers in front of me at the moment...But off the top of my head I'm thinking you've listed a valid number for the center carb metering block...Does'nt it look like the one in my pic {other than the tube you need to add for the distributor vac advance} ??? What makes you think it's the wrong block ??? Just asking...
70 440 metering block is stamped 6020,69 1/2 is 6170 and 340 is 6620.
And 4144,same as 6020.
[Re: Moparnut426]
#1159524
01/17/12 08:07 PM
01/17/12 08:07 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Well there you have it...But the dowel would'nt be a deal breaker for use...Next question would be {to cover all the bases} did the block numbers get superseded with any new/repop units ???
