brake hoses source and options? #1158122
01/15/12 07:17 PM
01/15/12 07:17 PM
Fresno, CA
cudamank Offline OP
cudamank  Offline OP
Fresno, CA
I need to replace the rear brake hose on my car, it is after all 42 years old and has developed a leak. Looking for options and sources. None of my local stores carries the rubber lines, and wondering if I should upgrade to a stainless flex line. Suggestions?
Remember remember the 11th of September, of murder and a terriosts plot. I see no reason why this treachery should ever be forgot.
Re: brake hoses source and options? [Re: cudamank] #1158123
01/15/12 08:28 PM
01/15/12 08:28 PM
Really?
I got the one for my '63 at O'Reilly's.
I had to ask for a '70 Charger IIRC.
Re: brake hoses source and options? #1158124
01/15/12 08:34 PM
01/15/12 08:34 PM
Greer, SC
TooMany62s Online content
TooMany62s  Online Content
Greer, SC
I got the front and rear hoses for my '62 Plymouth at NAPA. They have a pretty full line. You can check availability on their website. Rockauto.com is probably a good option too.
Re: brake hoses source and options? [Re: TooMany62s] #1158125
01/15/12 09:50 PM
01/15/12 09:50 PM
Central TX
roe Offline
roe  Offline
Central TX
I've always had great.luck with Autozone.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: brake hoses source and options? [Re: TooMany62s] #1158126
01/16/12 06:44 AM
01/16/12 06:44 AM
Fresno, CA
cudamank Offline OP
cudamank  Offline OP
Fresno, CA
Autozone, Oreilly, and Napa do not have a listing for it. Is there one from a C body that would fit?
Re: brake hoses source and options? [Re: cudamank] #1158127
01/16/12 06:52 AM
01/16/12 06:52 AM
Greer, SC
Greer, SC
What's the application?
Re: brake hoses source and options? [Re: TooMany62s] #1158128
01/16/12 06:42 PM
01/16/12 06:42 PM
Fresno, CA
cudamank Offline OP
cudamank  Offline OP
Fresno, CA
that is an excellent question.
70 plymouth Cuda' Rear brake hose.
Sorry thought I had put that in my original post.
Re: brake hoses source and options? [Re: cudamank] #1158129
01/16/12 06:50 PM
01/16/12 06:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There was a post about this before. It was said that in 1970 the rear brake hose screws into the T on the rear axle. Other years have the hose crimped onto the T. I know the parts stores carry the later crimped style but not the 1970 one. I don't know if the later year style will work for you or not.
Re: brake hoses source and options? [Re: cudamank] #1158130
01/16/12 08:15 PM
01/16/12 08:15 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I've never had any problems getting that part for any year from the local parts store. Try a 1971 Road Runner or other B Body, I'm sure it's the same.
Re: brake hoses source and options? [Re: DANA60] #1158131
01/16/12 09:10 PM
01/16/12 09:10 PM
Greer, SC
Greer, SC
Re: brake hoses source and options? [Re: TooMany62s] #1158132
01/16/12 09:14 PM
01/16/12 09:14 PM
Greer, SC
Greer, SC
Or try looking up this one on Rockauto.com:
BH36648
Re: brake hoses source and options? [Re: burdar] #1158133
01/16/12 09:24 PM
01/16/12 09:24 PM
scratchnfotraction Offline
this is a screw in hose on a 3 port brass block with vent bolt from a 67 polara 8 3/4 IIRC
does it look like yours on the 70?
Re: brake hoses source and options? [Re: TooMany62s] #1158134
01/16/12 09:25 PM
01/16/12 09:25 PM
GA
roadrunninMark Offline
GA
Call up Randy at Dixie Restorations,770-975-9898. I bought my brake lines and fuel lines from him. He can get you the stainless one as well, that is what I got.
Mark
Re: brake hoses source and options? [Re: roadrunninMark] #1158135
01/17/12 04:32 AM
01/17/12 04:32 AM
Fresno, CA
cudamank Offline OP
cudamank  Offline OP
Fresno, CA
thank you or the links. It does screw into the block. I will give the other two sites a call in the morning. Been great weather and the girl needs to be on the road, now hiding in the garage.
