Location of VIN# on the body of a 68 Charger #1158103
01/15/12 07:11 PM
01/15/12 07:11 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
I have a VIN# question. Besides the radiator core support does a 68 Charger have the Vin # located anywhere else?
thanks
Re: Location of VIN# on the body of a 68 Charger [Re: batt2rm] #1158104
01/15/12 07:12 PM
01/15/12 07:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not on core support in 68.
Re: Location of VIN# on the body of a 68 Charger [Re: buildanother] #1158105
01/15/12 07:34 PM
01/15/12 07:34 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Where else would VIN# be if not on core support?
Re: Location of VIN# on the body of a 68 Charger [Re: batt2rm] #1158106
01/15/12 07:43 PM
01/15/12 07:43 PM
chicagoland,usa
chicagoland,usa
Dash frame, and part of it may be on rear of block and possibly on trans.
Re: Location of VIN# on the body of a 68 Charger [Re: buildanother] #1158107
01/15/12 07:47 PM
01/15/12 07:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Radiator support in '68 should have the Order # stamped on, look on the upper yoke near the battery. Order # is also on fender tag. Might also be #s stamped on left quarter trunk rail like on my '68 RR.
Re: Location of VIN# on the body of a 68 Charger [Re: topside] #1158108
01/15/12 08:14 PM
01/15/12 08:14 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The SO# is on the core support , should be on the face that the rad may partially block, and under the trunk gasket on the drivers side . The VIN is NOT stamped anywhere on a 68 other than the tag on the dash .
Re: Location of VIN# on the body of a 68 Charger [Re: JohnRR] #1158109
01/15/12 08:19 PM
01/15/12 08:19 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So 40+ years later, what significance does a stamped SO# have? Sorry to rehash this, but is this the numbering system across the board?
Re: Location of VIN# on the body of a 68 Charger [Re: jcc] #1158110
01/15/12 08:31 PM
01/15/12 08:31 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Not until 1969 were the VIN's put on the body. The SO# is on the broadcast sheet as well as the fender tag and the used as the body stamps, more of an internal Chrysler thing than anything. Sometime in 68 the VIN numbers were put on the engine and trans, then in 69 they made it to the body. As for as significance, not really sure of what you are asking?
JB Rhinehart, Realist
A-Body's RULE!
Re: Location of VIN# on the body of a 68 Charger [Re: Rhinodart] #1158111
01/15/12 08:39 PM
01/15/12 08:39 PM
JohnRR Offline
JohnRR  Offline
What he said, though the VIN on engine and trans is hit or miss , I had a sept 67 built 68 wit hthe engine and trans vin stamped , and a later marchish built 68 without the engine stamped.
The significance is it is the only way to tie the body to an ORIGINAL fender tag , to tie the VIN to the fendertag you need the broadcast sheet and/or the ibm/punch card ... which doesn't exist for 68 and up ...
Re: Location of VIN# on the body of a 68 Charger [Re: JohnRR] #1158112
01/16/12 12:06 AM
01/16/12 12:06 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
In '68 ALL performance engines (P, H, L & J) & their associated transmissions were stamped with the last 8 of the VIN# (340 383 4bbl 440HP & HEMI). As these saw the majority of warranty claims due to their intended purposes. Lesser drivetrains were NOT stamped.
The S.O.# can be matched to an appropriate VIN# if one has a large enough database to access, I have a pretty good '68 Charger database - GG & a number of others do also.
If it gets to the point of a legal issue, the authorities have records to match the correct body numbers with the correct VIN#: subpoena 'n lawyers 'n $$$s etc.
Re: Location of VIN# on the body of a 68 Charger [Re: 6bblgt] #1158113
01/16/12 12:18 AM
01/16/12 12:18 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
with Dan
Re: Location of VIN# on the body of a 68 Charger [Re: ScottSmith_Harms] #1158114
01/16/12 02:04 AM
01/16/12 02:04 AM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
Not to thread jack, but can someone tell me all the places on a 70 Cuda convertible? I know of two on the body. Curious if there's more.
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
Re: Location of VIN# on the body of a 68 Charger [Re: MoparPosterChild] #1158115
01/16/12 02:13 AM
01/16/12 02:13 AM
JohnRR Offline
JohnRR  Offline
that is it .. cowl and rad support ... aside from the vin tag , the door sticker and the fender tag
