when did Fuel Injection start? #1156503
01/13/12 08:56 PM
01/13/12 08:56 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Looking for a motor, 360\318, and was trying to figure out what year fuel injection started.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: when did Fuel Injection start? [Re: roe] #1156504
01/13/12 09:01 PM
01/13/12 09:01 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
That depends, are you looking for ANY efi, or a good system? As far as LA engines, I think 1981? was when the first efi came out. Late 80s was the tbi systems in the trucks, and Magnum PFI came out in 1992 for 318s and 1993 for 360s
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: when did Fuel Injection start? [Re: 69L78Nova] #1156505
01/13/12 09:08 PM
01/13/12 09:08 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Maybe I should have worded that better. I actually want to avoid all that stuff, want to pick up something carbed
Re: when did Fuel Injection start? [Re: roe] #1156506
01/13/12 09:12 PM
01/13/12 09:12 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Almost all mopar V8's were carbed until the late 80's. ARound '88 or so when TBI systems came into use. In the early '80's were the fuel injected 318 Imperials and they were duds. Back in the 50's there was mechanical fuel injection and that didn't work so well either.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: when did Fuel Injection start? [Re: GO_Fish] #1156507
01/13/12 10:22 PM
01/13/12 10:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
88 was first year for the 318 and 89 for the 360. Both were throttle body inj until 92 I believe. Ron
Re: when did Fuel Injection start? [Re: 383man] #1156508
01/13/12 10:30 PM
01/13/12 10:30 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Ok, thanks guys. I found a few motors for $300-500. Mostly 318's but a few 360'a in that range as we'll. It's for a 84 ramcharger that I picked up. I wanna try and put another 360 back in, but if I find a 318 for the right price, then that's what it's getting.
Thanks again
Re: when did Fuel Injection start? [Re: roe] #1156509
01/13/12 11:59 PM
01/13/12 11:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Any of the injected 318/360's can be changed back to carb with a minimum of effort.
Re: when did Fuel Injection start? [Re: DaytonaTurbo] #1156510
01/14/12 09:19 AM
01/14/12 09:19 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Acually, Mopar EFI was first used in 1958.Dave
Re: when did Fuel Injection start? [Re: DaytonaTurbo] #1156511
01/14/12 09:28 AM
01/14/12 09:28 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup. and make more power to boot.
go get a Magnum small block, they have better heads and roller cams vs the LA engines. and they bolt right in like an LA block.
all you need to do is change the intake manifold and distributor, and your 2001 5.9L EFI motor just turned into a "1970s carb'ed V8"
unless you were going for originality, I see no reason to go with an LA motor
**Photobucket sucks**
Re: when did Fuel Injection start? [Re: quickd100] #1156512
01/14/12 09:40 AM
01/14/12 09:40 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
That was the first thing that came to mind for me too. Probably because I have this ol' NE57 laying around.
Moparlee
Re: when did Fuel Injection start? [Re: Robbins] #1156513
01/14/12 11:38 AM
01/14/12 11:38 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Actually, the Electrojector, indeed used in 1958, was an option reserved for big block models
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: when did Fuel Injection start? [Re: 69L78Nova] #1156514
01/14/12 11:46 AM
01/14/12 11:46 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
and the big block was the 350ci-----and no not yet chevy guys---bob
Re: when did Fuel Injection start? [Re: savoy64] #1156515
01/14/12 11:52 AM
01/14/12 11:52 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
On American production cars,both GM and AMC beat us by a year !
Re: when did Fuel Injection start? [Re: quickd100] #1156516
01/14/12 12:15 PM
01/14/12 12:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
NOT ON A 318 or 360 which is what the question was about.
If you really want to be pedantic the first mopar engine to be FI was in WWII, http://en.wikipedia.org/wiki/Chrysler_IV-2220
Don't be the exception.
Re: when did Fuel Injection start? [Re: Supercuda] #1156517
01/14/12 02:12 PM
01/14/12 02:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I thought he only asked about the 318 and 360 but I have been known to be wrong before. I do remember the Fuel injecton on the 300's with the 392 Hemi's were all recalled in 58 and changed back to carbs as far as I have heard. But I also heard one or two may still be out there with the injection on the 392 Hemi 300. Ron
Re: when did Fuel Injection start? [Re: 70Cuda383] #1156518
01/14/12 02:14 PM
01/14/12 02:14 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I get what u guys are saying, I thought about that too. But will it drop right in with the serpentine setup, or will I need to swap over the LA accessories? Isn't there an issue with getting the alternator to line up when swapping over the LA accessories? I had thought about going magnum with my satellite too, but ended up just dropping in an LA motor that I got a good deal on. If it won't increase the cost too much, magnum is an option
Re: when did Fuel Injection start? [Re: 62maxwgn] #1156519
01/14/12 03:11 PM
01/14/12 03:11 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Nope.
GM didn't have ELECTRONIC fuel injection, it was caveman mechanical injection on a Chevy.
CrAzYMoPaRGuY
Re: when did Fuel Injection start? [Re: roe] #1156520
01/14/12 04:54 PM
01/14/12 04:54 PM
Andrewh Online content
Andrewh  Online Content
It should drop right in, I had custom lines made for the a/c and the power steering though. the connectors were not the same.
wasn't expensive though. like 50 bucks for both.
There are 2 issues though.
1 is the fan. I did not deal with this as I went electric. I don't know if there is a short snout for a car for the fan on the truck motors.
2 is the fuel pump. you will have to go electric.
I suppose 3rd issue will be the inlet and outlet for the radiator/water pump.
top goes to the driver side, bottom goes to passenger.
Re: when did Fuel Injection start? [Re: 383man] #1156521
01/14/12 06:44 PM
01/14/12 06:44 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
There is 1 known to exist. A '58 Desoto Adventurer Convert. The owner found a recalled unit that was taken off a car and never returned to Chrysler. The restored car was very likely the car the original unit came from. Dave
Re: when did Fuel Injection start? [Re: CrAzYMoPaRGuY] #1156522
01/14/12 06:57 PM
01/14/12 06:57 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Nope.
The question was,when did "fuel injection" start ?
