XX29; '69 Charger 500 project - 01/16/2012
#1155982
01/13/12 11:41 AM
01/13/12 11:41 AM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: XX29; '69 Charger 500 project.
[Re: hemi68charger]
#1155983
01/13/12 02:23 PM
01/13/12 02:23 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Nice car! You're spoiled. You think those are rusty brake lines? Can I send you some from a typical MN car to show you what rusty is?
Good luck with the project!
Lead, follow or get the hell out of the way
[Re: hemi68charger]
#1155985
01/15/12 10:24 PM
01/15/12 10:24 PM
hemi68charger
Houston, Tx
More stuff.... Putting the driver's side caliper back together and mounted in the car. Fit's pretty good. Glad I did this for the Bendix system is pretty easy.... New calipers seals, new hoses and as seen before, new lines... I removed the old front-2-rear line and the Dana lines as well. I'll tackle the passenger side here in the coming week along with installing the new Dana lines, wheel cylinders and hardware kit... Rest of the car doesn't look all that pretty, but, I'll get to that later.. I just wanna get the car going down the road...
Re: XX29; '69 Charger 500 project - 01/16/2012.
[Re: hemi68charger]
#1155986
01/15/12 10:25 PM
01/15/12 10:25 PM
hemi68charger
Houston, Tx
2
[Re: upnover]
#1155990
01/17/12 03:07 PM
01/17/12 03:07 PM
hemi68charger
Houston, Tx
nice build it looks very solid i will be following it, what options does the 500 have?
Option-wise: A01: light package
A32: Super high performance axle axle package which includes - 4.10 Dana - 26" radiator high perf. w/shroud - 7-blade fan - front power disc brakes - power steering
C16:console for auto
XX29; '69 Charger 500 project. update 03/13/12
[Re: hemi68charger]
#1155991
03/13/12 11:08 AM
03/13/12 11:08 AM
hemi68charger
Houston, Tx
Well, things are wrapping up on the hydraulic brake system. I've replaced all the lines, cleaned out the valving and replaced the master cylinder. I attached it to the power brake booster and freshened up the unit with a fresh coat black. I'm going to see about turning the drums and getting hardware.... After I get the brakes all bleed and good to go, new fuel lines are next.............
Here's I'm getting ready to paint the power bracke booster/master cylinder unit. It cleaned up rather nicely and then reman M/C.
[Re: hemi68charger]
#1155992
03/13/12 11:10 AM
03/13/12 11:10 AM
hemi68charger
Houston, Tx
Almost done painting...
[Re: hemi68charger]
#1155993
03/13/12 11:10 AM
03/13/12 11:10 AM
hemi68charger
Houston, Tx
Temporarily installed. Waiting to get the harness clip/bracket that attaches to the backing plate...
Re: XX29; '69 Charger 500 project. update 03/13/12
[Re: 1970A13]
#1155995
03/19/12 12:04 AM
03/19/12 12:04 AM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
Troy,nice looking car,can't go wrong with a32 axle pkg.Havent seen to many 500's what are the hoses from the firewall for?I thought they have fixed headlights!Scott.
The C500s were converted from R/Ts... Sometimes they cut the hoses off at the firewall, other times they wrapped them with electrical tape and hung them somewhere... True craftsmen those Creative Industries guys..
[Re: 1970A13]
#1155998
06/27/12 08:04 PM
06/27/12 08:04 PM
hemi68charger
Houston, Tx
Update: Grille... I'm slowly getting the grille all squared away now. I have an NOS passenger side headlamp bucket and the attach brackets. What I was in need of was the inside vertical support brackets and driver's side headlamp bucket (which is IMPOSSIBLE) to find. I feel I'm extremely lucky to have found the NOS passenger side. Anywho, here's what I did/doing as of today...
Majority of what I have to start with...
[Re: hemi68charger]
#1155999
06/27/12 08:06 PM
06/27/12 08:06 PM
hemi68charger
Houston, Tx
Fitting the NOS bucket in.....
[Re: hemi68charger]
#1156000
06/27/12 08:07 PM
06/27/12 08:07 PM
hemi68charger
Houston, Tx
Grille fit with OEM brackets
[Re: hemi68charger]
#1156001
06/27/12 08:09 PM
06/27/12 08:09 PM
hemi68charger
Houston, Tx
Fitting the spacers in.... They were the same used on Coronets with length modifications.
