Stage 6 Heads valve location #1155782
01/13/12 09:15 AM
01/13/12 09:15 AM
Central Pa. U.S.A.
Bigfury Offline OP
Bigfury  Offline OP
Central Pa. U.S.A.
Had no luck with the search.Time to order pistons.Installing Mopar Stage 6 heads on top of a low deck.Is the valves in standard location on the Stage 6 heads? Need valve relieves in the pistons.Thanks in advance.
Re: Stage 6 Heads valve location [Re: Bigfury] #1155783
01/13/12 09:18 AM
01/13/12 09:18 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The location is same as production,but make sure they make the reliefs big enough for radial clearence with the bigger than production valves.
Keith
Re: Stage 6 Heads valve location [Re: Bigfury] #1155784
01/13/12 01:13 PM
01/13/12 01:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Scott - The valve reliefs in most aftermarket pistons will be fine for your build w/ my old Stage VI heads; just verify that they're designed for at least a 2.14" intake / 1.81" exhaust. That's even on the small side these days since many pistons are designed around 2.19"+ intake valves used on some other common aftermarket heads (e.g. Indy).
