Has anyone braced a K-frame in the car? #1155320
01/12/12 03:33 PM
01/12/12 03:33 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Just curious, the combination of R compound rubber and the longer T/A pitman arm in my challenger has really tweaked my power steering gearbox mount to the point where the bolts loosen after a hundred miles or so. Its going to be a long time until I have a chance to pull the motor and K-member to do it on the bench. Anyone done it in the car with the motor in?
Thanks,
-Jon
(And thanks Tom for the forum!)
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Has anyone braced a K-frame in the car? [Re: blown340] #1155321
01/12/12 03:40 PM
01/12/12 03:40 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Look closely at how the steering box plate is welded in, or I should say not really welded in.
On my Challenger with the k member out and clean, took a few minutes with the mig to just completely weld everywhere that the steering plate could be welded.
lot stronger and solid after welding
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Has anyone braced a K-frame in the car? [Re: moparts] #1155322
01/12/12 05:47 PM
01/12/12 05:47 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
I recently did the K frame in my Cuda, granted the car is still in peieces, however I did a consdierable amount of research on my front suspension. First stop is Firm Feel, look at thier welded K frame. I think they still do them by request, but anyone with a welder can do it. I welded up all of the seams but more to your point, I welded/re-welded up all of the steering box mounts. Most of them were merely tacked in place. The is enough bracing already in there (unless someone before was trying to lighten the car in the wrong place), however they need to be reinforced by welding all of them. The one spot the FF (and subsequently I) added bracing is behind the steering box mount which is hallow. it doesnt take a lot of metal to fill it in to create a very solid mount.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: Has anyone braced a K-frame in the car? [Re: 70chall440] #1155323
01/12/12 06:41 PM
01/12/12 06:41 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Yes, a welded k frame will transform your car. It's just that it's a pita to do if the car is assembled. You can suspend everything and remove it...
The steering box mount is most important area as there is a tremendous amount of flex that occurs when you turn the steering wheel.
Re: Has anyone braced a K-frame in the car? [Re: ThermoQuad] #1155324
01/12/12 06:55 PM
01/12/12 06:55 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Do you have more pictures that show where more plate and welding is required? Do you think some lightening holes would weaken the attempt to reinforce the structure.
I never gave any thought to welding up the K frame before. I had always thought that it should be good enough. I guess that I will learn something new here everyday.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Has anyone braced a K-frame in the car? [Re: racealittle] #1155325
01/12/12 07:23 PM
01/12/12 07:23 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I've been reading more and more about the gains to be found in chassis stiffening, and this thread makes as much sense as subframe connectors. I have a spare 70 B body V8 K member and I was planning on making these upgrades. Maybe I'll take step by step pictures for a future thread.
Re: Has anyone braced a K-frame in the car? [Re: Kern Dog] #1155326
01/12/12 07:42 PM
01/12/12 07:42 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Another "welded up the stock stuff" guy here. Last time I had the motor out I pulled the K member and welded that thing up proper. Gusseted the motor mounts and steering box a little, but mostly put in better/more welds than the crappy factory job. I put in a firm feel box and decided to double the amount of weld holding the box mount to the K. I also put in the big Hotchkiss sway bar and didn't like how the mounts were 1/2 suspended in mid-air so I ran a brace from the front of the mount to the top of the K.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Has anyone braced a K-frame in the car? [Re: racealittle] #1155327
01/12/12 08:36 PM
01/12/12 08:36 PM
ThermoQuad Offline
ThermoQuad  Offline
putting lightening holes in the k frame is "feathers"
Every seam is welded, turn the voltage up and the feed down and weld.
Re: Has anyone braced a K-frame in the car? [Re: ThermoQuad] #1155328
01/12/12 10:05 PM
01/12/12 10:05 PM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
one piece of advice I would offer is, if possible have your K frame "cooked" to clean it, or at a minimum use a lot of degreaser and high pressure to get the inside clean. If not, you will constantly be blowing out the grease fires that flare up from all of the crud inside of the K frame. One other point that was brought to my attention is, dont try and weld it all at once. Jump aound and weld a couple of inches at a time, especially around the seam. This will ensure you don't tweak the frame due to heat. I didnt do this on purpose but more by accident. While I was at a local Mopar restoration shop, the owner was telling another guy a story about a K Frame he had that someone had started on one side an started pouring heat/weld into the frame. When he tried to bolt it up, the frame was twisted some. He attributed this to the welding technique. I dont think this is a huge issue or something that is easy to screw up, I just think it is better to be safe than pissed off. I would also recommend welding the seams around the frame and then weld/brace up the steering box area; that way nothing should move. Could be wrong here but that seems to be logical to me.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Has anyone braced a K-frame in the car? [Re: 70chall440] #1155329
01/13/12 01:01 AM
01/13/12 01:01 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Did this in 1997.
I've since bent a steel 15x8 rim going off course at Willow. To the core, not just the outer rim. But I've taking the motor out and inspected with a fine toothed comb and no problems.
Now my Mopar remanufacture steering box with 80K miles is toast though. I did get 80K miles from it, but it's unscrewing itself from the input side spanner and regular adjustment nut. Lower bearing moves around after as much adjustment as possible while still in car. I think it's just taken too many "shots to the head."
Re: Has anyone braced a K-frame in the car? [Re: autoxcuda] #1155330
01/14/12 06:37 AM
01/14/12 06:37 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My computer is not opening Tom's attachments, can someone post some good pics of the reinforcements they welded around the steering box mount? Maybe some pics of the control arm attaching points? Thanks Tim
Re: Has anyone braced a K-frame in the car? [Re: astjp2] #1155331
01/14/12 07:03 AM
01/14/12 07:03 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: Has anyone braced a K-frame in the car? [Re: autoxcuda] #1155332
01/20/12 06:19 AM
01/20/12 06:19 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
Did this in 1997.
Before someone was to weld up a k member like this, is there anyway to determine if it is straight beforehand. Not as in wrecked and bent but like made correctly. I have read that the quality varied greatly. I guess what i'm saying is there a "blueprint" so you could do some measuring and make sure everything is where it should be. Or if you have a half dozen k's laying around find out which one is the nost correct of the bunch before you do all the work to it?
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: Has anyone braced a K-frame in the car? [Re: rtidd440] #1155333
01/20/12 10:05 PM
01/20/12 10:05 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Interesting thought.
I too have heard of the production variances in quality with k members. It seems that there has to be a better way to determine their accuracy than taking measurements with the K IN the car with all the other components attached.
Re: Has anyone braced a K-frame in the car? [Re: blown340] #1155334
01/22/12 12:57 PM
01/22/12 12:57 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Another approach: Adding Firm Feel's lower sector shaft support bearing kit stops the pitman from being cantilevered out there and reduces K-member flex a whole bunch -- and it is a 10-minute bolt-on!
OK, guess who designed it... ;->
Rick E.
Re: Has anyone braced a K-frame in the car? [Re: Rick_Ehrenberg] #1155335
01/22/12 02:55 PM
01/22/12 02:55 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Any installed pics?
And the purpose, if I understand it correctly, is to prevent "flexing" of the 1.25"? sector shaft, to lighten the load on the OEM sector bearings, AND to basically supply another mounting point for the PS box? I can't imagine shaft has much relative flex in the scheme of things.
Re: Has anyone braced a K-frame in the car? [Re: jcc] #1155336
01/22/12 03:40 PM
01/22/12 03:40 PM
ThermoQuad Offline
ThermoQuad  Offline
The bearing is a nice idea but is the new bearing kit a fix for those who won't or can't or don't want to weld their k frame? It seems a properly welded/reinforced k frame would not require this additional piece as the steering box is now held very rigidly.
Has an evaluation been done to see if there is any discernible flex in the steering box mount after a full gusset and weld?
Re: Has anyone braced a K-frame in the car? [Re: Rick_Ehrenberg] #1155337
01/23/12 12:14 AM
01/23/12 12:14 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
Rick E.
Was hoping to see you chime in on this one. Those are for sure on my list for any of my non resto cars. How about it Rick. Got any factory blueprints for K members? Or how would you determine how "square" on was? Could you bolt everything to it and measure from one reference point? I know you have a way. BTW i have all of the MA's and some of your pre MA stuff. Refer to it often. First thing I read when the new issue shows up. Thanks man. Good job.
Re: Has anyone braced a K-frame in the car? [Re: ThermoQuad] #1155338
01/23/12 11:13 PM
01/23/12 11:13 PM
Marlboro, NY, USA
Marlboro, NY, USA
I usually use the unscientific approach, by looking at how much the pressure hose's chuck end (on PS cars) moves around when moving the steering wheel back 'n' forth a few inches, car at rest. In fact, this is how I discovered K flex 40 years ago!
From what I've seen, this simple bolt-on helps more than all the gusseting I've done over the years, and that's a lot! In fact, unless I was building another real road racer or auto-X'er, this is all I would bother with.
Again, I haven't measured, this is an eyeball estimation. Measurements, to be worth anything, would need to be done on the same car, same weight, same tire footprint and air pressure, etc.
Remember, no matter how much stiffness you add, the pitman (w/o the added bearing) will still be cantilevered out there.
'Course, it can never be too stiff... ;->
Rick
Re: Has anyone braced a K-frame in the car? [Re: Rick_Ehrenberg] #1155339
01/23/12 11:29 PM
01/23/12 11:29 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You may want to call your doctor if it remains that way for more than 4 hours! Hahahahaha
Rick
