Has anyone braced a K-frame in the car?
#1155320
01/12/12 03:33 PM
01/12/12 03:33 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Just curious, the combination of R compound rubber and the longer T/A pitman arm in my challenger has really tweaked my power steering gearbox mount to the point where the bolts loosen after a hundred miles or so. Its going to be a long time until I have a chance to pull the motor and K-member to do it on the bench. Anyone done it in the car with the motor in?
Thanks, -Jon
(And thanks Tom for the forum!)
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: Has anyone braced a K-frame in the car?
[Re: blown340]
#1155321
01/12/12 03:40 PM
01/12/12 03:40 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Look closely at how the steering box plate is welded in, or I should say not really welded in. On my Challenger with the k member out and clean, took a few minutes with the mig to just completely weld everywhere that the steering plate could be welded. lot stronger and solid after welding
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#1155322
01/12/12 05:47 PM
01/12/12 05:47 PM
Posts: 181 Washington State
70chall440
Washington State
I recently did the K frame in my Cuda, granted the car is still in peieces, however I did a consdierable amount of research on my front suspension. First stop is Firm Feel, look at thier welded K frame. I think they still do them by request, but anyone with a welder can do it. I welded up all of the seams but more to your point, I welded/re-welded up all of the steering box mounts. Most of them were merely tacked in place. The is enough bracing already in there (unless someone before was trying to lighten the car in the wrong place), however they need to be reinforced by welding all of them. The one spot the FF (and subsequently I) added bracing is behind the steering box mount which is hallow. it doesnt take a lot of metal to fill it in to create a very solid mount.
01 Viper GTS ACR 10 Challenger RT PCP 6spd 70 Challenger 440 6 pac 73 Cuda 416 Road Racer 70 Hemi Roadrunner 01 Ram 4x4 / 98 Ram 3500 91 Stealth RT 05 Durango Hemi 09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
[Re: ThermoQuad]
#1155324
01/12/12 06:55 PM
01/12/12 06:55 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Yes, a welded k frame will transform your car. It's just that it's a pita to do if the car is assembled. You can suspend everything and remove it...
The steering box mount is most important area as there is a tremendous amount of flex that occurs when you turn the steering wheel.
Do you have more pictures that show where more plate and welding is required? Do you think some lightening holes would weaken the attempt to reinforce the structure.
I never gave any thought to welding up the K frame before. I had always thought that it should be good enough. I guess that I will learn something new here everyday.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: Kern Dog]
#1155326
01/12/12 07:42 PM
01/12/12 07:42 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Another "welded up the stock stuff" guy here. Last time I had the motor out I pulled the K member and welded that thing up proper. Gusseted the motor mounts and steering box a little, but mostly put in better/more welds than the crappy factory job. I put in a firm feel box and decided to double the amount of weld holding the box mount to the K. I also put in the big Hotchkiss sway bar and didn't like how the mounts were 1/2 suspended in mid-air so I ran a brace from the front of the mount to the top of the K.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: ThermoQuad]
#1155328
01/12/12 10:05 PM
01/12/12 10:05 PM
70chall440
Washington State
one piece of advice I would offer is, if possible have your K frame "cooked" to clean it, or at a minimum use a lot of degreaser and high pressure to get the inside clean. If not, you will constantly be blowing out the grease fires that flare up from all of the crud inside of the K frame. One other point that was brought to my attention is, dont try and weld it all at once. Jump aound and weld a couple of inches at a time, especially around the seam. This will ensure you don't tweak the frame due to heat. I didnt do this on purpose but more by accident. While I was at a local Mopar restoration shop, the owner was telling another guy a story about a K Frame he had that someone had started on one side an started pouring heat/weld into the frame. When he tried to bolt it up, the frame was twisted some. He attributed this to the welding technique. I dont think this is a huge issue or something that is easy to screw up, I just think it is better to be safe than pissed off. I would also recommend welding the seams around the frame and then weld/brace up the steering box area; that way nothing should move. Could be wrong here but that seems to be logical to me.
[Re: 70chall440]
#1155329
01/13/12 01:01 AM
01/13/12 01:01 AM
Posts: 27,470 So Cal
autoxcuda
So Cal
Did this in 1997. I've since bent a steel 15x8 rim going off course at Willow. To the core, not just the outer rim. But I've taking the motor out and inspected with a fine toothed comb and no problems. Now my Mopar remanufacture steering box with 80K miles is toast though. I did get 80K miles from it, but it's unscrewing itself from the input side spanner and regular adjustment nut. Lower bearing moves around after as much adjustment as possible while still in car. I think it's just taken too many "shots to the head."
[Re: astjp2]
#1155331
01/14/12 07:03 AM
01/14/12 07:03 AM
autoxcuda
So Cal
My computer is not opening Tom's attachments, can someone post some good pics of the reinforcements they welded around the steering box mount? Maybe some pics of the control arm attaching points? Thanks Tim
[Re: blown340]
#1155334
01/22/12 12:57 PM
01/22/12 12:57 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Another approach: Adding Firm Feel's lower sector shaft support bearing kit stops the pitman from being cantilevered out there and reduces K-member flex a whole bunch -- and it is a 10-minute bolt-on! OK, guess who designed it... ;-> Rick E.
[Re: Rick_Ehrenberg]
#1155335
01/22/12 02:55 PM
01/22/12 02:55 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Any installed pics? And the purpose, if I understand it correctly, is to prevent "flexing" of the 1.25"? sector shaft, to lighten the load on the OEM sector bearings, AND to basically supply another mounting point for the PS box? I can't imagine shaft has much relative flex in the scheme of things.
[Re: ThermoQuad]
#1155338
01/23/12 11:13 PM
01/23/12 11:13 PM
Rick_Ehrenberg
Marlboro, NY, USA
The bearing is a nice idea but is the new bearing kit a fix for those who won't or can't or don't want to weld their k frame? It seems a properly welded/reinforced k frame would not require this additional piece as the steering box is now held very rigidly.
Has an evaluation been done to see if there is any discernible flex in the steering box mount after a full gusset and weld?
I usually use the unscientific approach, by looking at how much the pressure hose's chuck end (on PS cars) moves around when moving the steering wheel back 'n' forth a few inches, car at rest. In fact, this is how I discovered K flex 40 years ago!
From what I've seen, this simple bolt-on helps more than all the gusseting I've done over the years, and that's a lot! In fact, unless I was building another real road racer or auto-X'er, this is all I would bother with.
Again, I haven't measured, this is an eyeball estimation. Measurements, to be worth anything, would need to be done on the same car, same weight, same tire footprint and air pressure, etc.
Remember, no matter how much stiffness you add, the pitman (w/o the added bearing) will still be cantilevered out there.
'Course, it can never be too stiff... ;->
Rick
