TTI's x-pipe or h-pipe #1155147
01/12/12 02:17 AM
01/12/12 02:17 AM
alaska
69 mayflower Offline OP
alaska
I am going to install TTI's 2 1/2" exhaust system on my '69 Sport Satellite.Basically stock 383 with an automatic transmission.I will be using the factory hi-performance manifolds.Is there any reason to spend the few extra dollars for the x-pipe system over the h-pipe system on a stock build.Any pro's or con's regarding TTI's systems from you guys that have experience with them would be appreciated.
1969 Plymouth Sport Satellite 383 1990 Dodge W150 plowtruck 318 2012 Dodge Ram 1500 4WD 5.7 HEMI 2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
Re: TTI's x-pipe or h-pipe [Re: 69 mayflower] #1155148
01/12/12 07:56 AM
01/12/12 07:56 AM
An X pipe gives significantly more noise reduction than an H system just from it's accoustical properties which will let you use a more free flowing (louder) muffs for more HP and still have an acceptable noise level. The most restricted aspect of the total air pump (the eng) typically is the ex. I would suggest mandrel bends.
Re: TTI's x-pipe or h-pipe [Re: RapidRobert] #1155149
01/12/12 08:00 AM
01/12/12 08:00 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Check out some you-tube clips, the X changes the sound over the H. I don't like the X pipe sound at all. The X seems to give a more modern mellow smooth sound where the H gives more of that rumbley old school sound.
Re: TTI's x-pipe or h-pipe [Re: DaytonaTurbo] #1155150
01/12/12 09:33 AM
01/12/12 09:33 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
always though my car had a nice sound.
tti headers, 3" x-pipe system to the rear bumper using dynomax super turbo mufflers..
http://www.youtube.com/watch?v=f7f9x4FKO6I
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: TTI's x-pipe or h-pipe [Re: DaytonaTurbo] #1155151
01/12/12 09:35 AM
01/12/12 09:35 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I had the TTI X-pipe system on my Hemi Challenger and I didn't think it was loud enough for me. I would hear 383 Roadrunners idle past me like at Carlisle and they would sound way cooler, Also mine did sound good at WOT, but I couldn't do that alot.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: TTI's x-pipe or h-pipe [Re: bobbyb] #1155152
01/12/12 06:14 PM
01/12/12 06:14 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I like the TTi 3 inch system with x-pipe and dynomax's, but my car sounds coolest with the electric exhaust cutouts and small megaphone tip wide open just in front of the cross-over.
It's the best of both worlds, and you can open them a little or all the way to suit the venue.
I've since had the entire exhaust system coated in black ceramic. It looks much cooler now.
Re: TTI's x-pipe or h-pipe [Re: jbc426] #1155153
01/12/12 10:14 PM
01/12/12 10:14 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
since your running a stock 383 all you need is the 2 1/2" exhaust - couldn't he just run a 3" exhaust if he wanted it to be "louder?"
Re: TTI's x-pipe or h-pipe [Re: dangina] #1155154
01/12/12 10:44 PM
01/12/12 10:44 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
With a stock motor,go the H pipe route.
Quiet when at cruising speed and has a nice smooth tone at idle.
Still have a snarly bark when goosing it,too.
Engine temps will come down,and you will see better fuel economy.
I did with the TTi 2-1/2 inch system with Dynomax Super Turbo's..
The X pipe has more flow,but recommend it for a more powerful motor that is more strip/street.
Re: TTI's x-pipe or h-pipe [Re: 68Cbarge] #1155155
01/12/12 11:23 PM
01/12/12 11:23 PM
alaska
alaska
Thanks for all the comments and pictures thus far.That will surely help me to decide which way to go.However, just to throw another kink into the works,since I've been doing exhaust system research,I've come across Accurate Exhaust who is a sponsor here on Moparts.It looks like they have a very nice system too.14 gauge pipe instead of TTI's 16 gauge.Tailpipe turndowns built in instead of the clamp on style that TTI has.However it looks like they have no crossover pipe for a 383 system.And if I read the diagram correctly,it's a 2 1/4" system for a 383.Also I'm not sure they are a mandrel bend system.So,here we go again.Any thoughts or comments on them.None of these are cheap,so I just want to be well informed before plunking down the money.
Re: TTI's x-pipe or h-pipe [Re: 69 mayflower] #1155156
01/13/12 12:06 AM
01/13/12 12:06 AM
PNW
Beebuzzn Online content
Beebuzzn  Online Content
PNW
Call Accurate and tell them what your looking for as they have and do alot of stuff not shown on their web page. Nice stuff.
Re: TTI's x-pipe or h-pipe [Re: Beebuzzn] #1155157
01/13/12 12:21 AM
01/13/12 12:21 AM
People's Republic of Kali
70runner Offline
70runner  Offline
TTI 2.5" H pipe (nice system, fits perfect):
here it run
Re: TTI's x-pipe or h-pipe [Re: 70runner] #1155158
01/13/12 01:59 AM
01/13/12 01:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use 2" TTI headers and a 3" system with an X-pipe and honestly it did not sound much different to me then the old H-pipe system. X-pipe will give a bit more HP. You can hear my car on this clip as I have Dyno-Max Ultra-Flows on it. Ron
http://www.youtube.com/watch?v=bYIM2HLaOI4&feature=related
Re: TTI's x-pipe or h-pipe [Re: 383man] #1155159
01/14/12 07:56 AM
01/14/12 07:56 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
love the looks and sound...TTI headers and H pipe factory looking turndowns out back.
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: TTI's x-pipe or h-pipe [Re: 72N96RR] #1155160
01/14/12 07:57 AM
01/14/12 07:57 AM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
other direction
