318/340 swap question or two..........
#1154790
01/11/12 04:44 PM
01/11/12 04:44 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
I am swapping a 318/904 to a 340/727. I should say I'm paying to have this swap done. The 340 and 727 were together at one time, but they were dressed down and striped when I got them.
I'm trying to find out if the crossmember from the 904 will mount the 727 or do I need to locate one? If so, where is the place to buy?
Are the Brackets from the 318 for the alternator and power stering pump the same?
Will the power streering pump from the 318 work on the 340?
Is there a source to get motor mounts for the 340?
I have a floor shift, with the linkage from the 904 hook up to the 727 or is that different?
Any help, would be sweet...............Thx Scott
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
Re: 318/340 swap question or two..........
[Re: fireeng]
#1154791
01/11/12 05:12 PM
01/11/12 05:12 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
I'm trying to find out if the crossmember from the 904 will mount the 727 or do I need to locate one? If so, where is the place to buy? yes the same
Are the Brackets from the 318 for the alternator and power stering pump the same? yes the same
Will the power streering pump from the 318 work on the 340? yes
Is there a source to get motor mounts for the 340? yes, the drivers engine bracket is different and available , everything else is the same
I have a floor shift, with the linkage from the 904 hook up to the 727 or is that different? Mostly all the same , the bracket to the trans tail may be different and also the shape of the linkage rod to the shifter lever on the trans . Any help, would be sweet...............Thx Scott
[Re: JohnRR]
#1154792
01/11/12 05:26 PM
01/11/12 05:26 PM
fireeng
near New Haven, CT
That just about covers that..... thanks JohnRR
more to follow....
[Re: Ron69rr]
#1154798
01/12/12 04:27 PM
01/12/12 04:27 PM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
Do you have to reverse the cross member as the lengths of the 904 and 727 were different iirc. I do know that the 3 and 4 speeds are different and require a different cross member.
No, mount pointis the same.
-Daty
[Re: Daty Rogers]
#1154799
01/12/12 07:29 PM
01/12/12 07:29 PM
JohnRR
U.S.S.A.
-Daty
What he said . He will need a shorter driveshaft if that wasn't already mentioned .
