Correct 1968 Hemi Waterpump bolts? #1154178
01/10/12 08:30 PM
01/10/12 08:30 PM
canada
marfen Offline OP
marfen  Offline OP
canada
I'm trying to figure out which are the correct bolts for my resto 68 Hemi car waterpump housing. Repros have an A with 3 slash grade 5 designation. As I dig thru my mopar bolt collection I'm finding E, S, etc. Anyone out there with an untouched 68 hemi car and know which is right? many thanks
Re: Correct 1968 Hemi Waterpump bolts? [Re: marfen] #1154179
01/10/12 09:09 PM
01/10/12 09:09 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The A bolts for your 4 water pump to the water pump housing bolts should be correct
Re: Correct 1968 Hemi Waterpump bolts? [Re: RoadRunnerJD] #1154180
01/10/12 11:14 PM
01/10/12 11:14 PM
canada
marfen Offline OP
marfen  Offline OP
canada
thank for the advice. I'm also wondering about the waterpump housing to block bolts too.
Re: Correct 1968 Hemi Waterpump bolts? [Re: marfen] #1154181
01/11/12 12:19 AM
01/11/12 12:19 AM
Warrenton, VA
Warrenton, VA
Someone has published a bolt guide for B-Body cars? My 69's are all H bolts including the long alternator bolt. I am guessing they are the same for 68? I had a 68 440 and the
Water pump housing bolts were H's. It would be the same on a Hemi. The short alternator bracket bolt on the top of the water pump is a slotted head Marsden bolt. Do you have power steering? What bolt markings do you have on your timing cover bolts?
Re: Correct 1968 Hemi Waterpump bolts? [Re: RoadRunnerJD] #1154182
01/11/12 09:25 AM
01/11/12 09:25 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Correct 1968 Hemi Waterpump bolts? [Re: Kowal] #1154183
01/11/12 10:24 PM
01/11/12 10:24 PM
canada
marfen Offline OP
marfen  Offline OP
canada
Cool, thanks guys , this all helps out greatly. A's and H's it is and I have some too luckily. That judging website helps out greatly too.
Re: Correct 1968 Hemi Waterpump bolts? [Re: Kowal] #1154184
01/12/12 12:02 AM
01/12/12 12:02 AM
Warrenton, VA
Warrenton, VA
http://www.iccahome.org/
I didn't see the A bolts with the three lines in their bolt guide but they are OK. M bolts with three lines are also OK for the water pump to housing. Doesn't the pulley hide the water pump bolts on a 68 Hemi?
Re: Correct 1968 Hemi Waterpump bolts? [Re: RoadRunnerJD] #1154185
01/13/12 12:51 AM
01/13/12 12:51 AM
canada
marfen Offline OP
marfen  Offline OP
canada
I was checking out the pics and noticed the A pump to housing bolts. Yep the pulley hides them but it will bug me if I don't do it right.
