Page 1 of 3 1 2 3
Mopar 14" trim rings from original re-worked tooling??? #115394
09/05/08 08:07 AM
09/05/08 08:07 AM
capac michigan
MCB Restorations Offline OP
capac michigan
If Mopar offered the original 14" trim ring again through the license program and the quality was good, what interest is there? Trying to understand the business case here. This part would come from original Chrysler tooling that has been slightly re-worked due to storage life damage.
Matt @ MCB
Stainless Steel and Aluminum trim restoration by MCB Restorations. We offer show quality trim restoration for all brands but specialize in Mopar. See our website for other examples www.mcbrestorations.com or give us a call at (810) 395-7162
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: MCB Restorations] #115395
09/05/08 08:12 AM
09/05/08 08:12 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Depends on price. I need a set of rings for my rallyes but I would quickly lose interest if they were priced at $100ea.
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: MCB Restorations] #115396
09/05/08 12:36 PM
09/05/08 12:36 PM
pgh pa
captaindodge Offline
pgh pa
Do you know that the 14 inch trim ring #2875758 is special for 1969 because it has a lip on the inner part of the ring. This is the trim ring that should be in demand for Charger Daytona & 500 models (really all 69 models). Galen says it is held on by 4 clips on the back.
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: captaindodge] #115397
09/05/08 08:15 PM
09/05/08 08:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Is that the ring that clips over the wheel edge and always runs into a wheel weight?
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: 6PakBee] #115398
09/05/08 09:26 PM
09/05/08 09:26 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Yep
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: MCB Restorations] #115399
09/06/08 10:42 PM
09/06/08 10:42 PM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
Matt @ MCB
Do you know what years the tooling would be for. 1969 or 1970 and up? I personally think the 1969 trim ring would be in high demand. I've seen my share of '69 Mopars with the wrong ones.
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: Mopar 14" trim rings from original re-worked toolin [Re: WORKER_BEE] #115400
09/06/08 11:54 PM
09/06/08 11:54 PM
New York, USA
fluegelmeister Offline
New York, USA
I would buy a set.
Barry
Re: Mopar 14" trim rings from original re-worked toolin [Re: fluegelmeister] #115401
09/07/08 01:26 AM
09/07/08 01:26 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I could really use 2.
Re: Mopar 14" trim rings from original re-worked toolin [Re: Mastershake340] #115402
09/07/08 08:56 AM
09/07/08 08:56 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I just paid $200 for ONE...So I would gladly buy a set as well
CHECK OUT MY NEW WEB SITE !
Re: Mopar 14" trim rings from original re-worked toolin [Re: anlauto] #115403
09/07/08 11:36 AM
09/07/08 11:36 AM
Lost in the 70's
440gtx6 Offline
440gtx6  Offline
Lost in the 70's
I could use a set for 70 road wheels.
69 EF8 GTX 440 auto
72 EB5 RR/GTX 440 auto
70 EW1 GTX 440-6 4 spd
70 EF8 Satellite 318 auto (452 coming soon)
70 FK5 Satellite 318 auto
71 FC7 Cuda 340 4 spd
Re: Mopar 14" trim rings from original re-worked toolin [Re: 440gtx6] #115404
09/07/08 11:57 AM
09/07/08 11:57 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The 70-71 style would also be in good demand, all 14.00 trim ring applications used the same rings; B,E, & A body and the current reproduction is off by a country mile in the valve stem cut out area.
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: MCB Restorations] #115405
09/07/08 03:28 PM
09/07/08 03:28 PM
Cincinnati area
sch1966 Offline
sch1966  Offline
Cincinnati area
I would be interested but for what it is worth people are offering to refinish originals for $55 each.
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: sch1966] #115406
09/09/08 02:45 PM
09/09/08 02:45 PM
Who does this and where are they located? I contacted about 2 dozen stainless steel resto shops two years ago when I was trying to get my original 69 trim rings done and no one would touch them. I ended up restoring them myself and bought a bunch of tools and restoration items through Eastwood and spend about 40-60 hrs on each (times 4) for my car. I still have a second set of them that still need to be restored and I would gladly pay $55 each to have them redone.
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: ] #115407
11/15/10 07:59 PM
11/15/10 07:59 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Any update on the 14" trim rings? I'd be interested in a set of brushed rings for a '73 Plymouth.
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: Dave Watt] #115408
11/15/10 08:20 PM
11/15/10 08:20 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Has anyone tried to brush the finish on the polished ones? http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: Dave Watt] #115409
11/15/10 09:11 PM
11/15/10 09:11 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I could use two for a '69 GTX but would buy a set of four (4) without hesitation if they were O.E. correct......and if they were made in the USA or Canada it's a no brainer IMO
MikeR
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: Dave Watt] #115410
11/15/10 10:32 PM
11/15/10 10:32 PM
cataclysm80 Offline
cataclysm80  Offline
With trim ring installed, put wheel on balancer to spin it. Apply scotch brite pad = brushed finish. DON'T HOLD THE SCOTCH BRITE PAD WITH YOUR HAND!!! (You might lose a finger!)
Tav
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: sch1966] #115411
11/15/10 11:48 PM
11/15/10 11:48 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Do they remove dings on the face of the trim ring for that price?
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: Dave Watt] #115412
11/16/10 11:30 AM
11/16/10 11:30 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I need a set for my 73 Challenger.
The rings are double walled. If there are dents, it makes it kind of hard to get in there to pound them out.
Re: Mopar 14" trim rings from original re-worked tooling??? [Re: MCB Restorations] #115413
11/17/10 04:57 PM
11/17/10 04:57 PM
MI
66500MPFI Offline
66500MPFI  Offline
MI
I might be interested at the right price.
Page 1 of 3 1 2 3
