65 b body transmission swap #1153432
01/09/12 12:55 PM
01/09/12 12:55 PM
SE Mi
U
use2teech Offline OP
U
SE Mi
I know lot's have run into this but I don't finjd the post....Going to swap a later model (67-7?) 727 into my 65 coronet big block. It currently has the original 65 727 with original floor shift and I want to keep that stock shifter. Anyone know what I will need to change out ?
Re: 65 b body transmission swap [Re: use2teech] #1153433
01/09/12 02:08 PM
01/09/12 02:08 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Check with Imperial Service's
Re: 65 b body transmission swap [Re: use2teech] #1153434
01/09/12 02:54 PM
01/09/12 02:54 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
IMP Serv's stuff is very VERY expensive .... I say ...keep what you have. What are your plans here ?
Re: 65 b body transmission swap [Re: use2teech] #1153435
01/09/12 03:33 PM
01/09/12 03:33 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Just curious. Why change?
Re: 65 b body transmission swap [Re: use2teech] #1153436
01/09/12 03:58 PM
01/09/12 03:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
is yours cable shift now!
I'd just swap the input of the 67 in if you want the newer input shaft??
Re: 65 b body transmission swap [Re: Dodgem] #1153437
01/09/12 05:39 PM
01/09/12 05:39 PM
SE Mi
U
U
SE Mi
Mine is cable shift now. bought the cables from Imperial. I am thinking of changing because after almost 2 years for putting the car together, I finally got it driveable (in the yard) and it has a huge trans leak from the bell housing. That's after I had it rebuilt and bought a new 65 only torq convertor. Just frustrated but everyone told me all along to dump that trans and go later model. Told me it would leak forever. Just not sure if I want to pull it out and fight leaks over and over......and thought maybe a TCI or A&A would be less trouble ???
Re: 65 b body transmission swap [Re: use2teech] #1153438
01/09/12 05:50 PM
01/09/12 05:50 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
They don't leak if everything is the way it should be.Very poor reasioning to change a transmission.
Re: 65 b body transmission swap [Re: 62maxwgn] #1153439
01/09/12 06:01 PM
01/09/12 06:01 PM
SE Mi
U
U
SE Mi
Poor reasoning maybe....frustration, definitely. Many people have much luck using this year/model trans ? I would much rather put the money into something else.
Re: 65 b body transmission swap [Re: use2teech] #1153440
01/09/12 06:04 PM
01/09/12 06:04 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Probably the front seal. No big deal.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 65 b body transmission swap [Re: use2teech] #1153441
01/09/12 08:18 PM
01/09/12 08:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Everyone" gave you poor advice...not uncommon.
Re: 65 b body transmission swap [Re: use2teech] #1153442
01/09/12 09:16 PM
01/09/12 09:16 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
More than likely improprly installed from pump bushing and the converter has snagged it and pulled it through the seal. Have seen this before. Also possible bad bushing or pump worn and won't hold bushing properly. Its easy enough to fix and as you have to pull the tranny anyway and have paid to have it built I would pull it, have the problem checked out and fix it.
Re: 65 b body transmission swap [Re: 82ramIndy493] #1153443
01/09/12 10:03 PM
01/09/12 10:03 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Before I changed over to a 4speed, I had a '65 cableshift 727 in my '65 Coronet 500. The input was changed in order to use later convertors, Cheetah valve body (revere pattern), and park system removed as in the A990 cars. Once in a while, a drip from the cable itself. Fixed that by removing the cable from the trans, removing the adjuster, cleaning with brake cleaner and carb cleaner, put rubber line over cable and filled between the cable and hose with RTV. Drier than a popcorn fart. FWIW, I'm sure that the 727 is stronger than the 833 also but not as much fun (for me).
Re: 65 b body transmission swap [Re: rbstroker] #1153444
01/09/12 10:37 PM
01/09/12 10:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
65 can easily be converted to late model converter. Less than $100 in parts,15 minutes worth of work with the trans on the bench. My new N/SS drag car has a 65 pushbutton. Should run low 9s. My old car ran low 10,over 1000 passes with a near stock 65 trans without failure.
Doug
