Slow Mopars #1152981
01/08/12 06:04 PM
01/08/12 06:04 PM
Central New York
slippery440 Offline OP
Crybaby440
Crybaby440
Central New York
With all the fastes this or that post and who has the fastes this or that. I want to see stock blocks / stock stroke crankshaft / no power adders at all. This means carburator only.(440-413-426 wedge-400-383-360-340-318- 273) Also it has to be running and ready to race or drive.This post is for the guys that have a regular job and can not afford a 605 cube motor that runs in the 8s and have a crew of guys hanging off it. Its for the weekend warrior or the weekend driver.
My JUNK
66 440 block bored over .30
KB Hyper pistons
Stock rods and steel crank
Comp roller cam .625 lift both sides
Harland Sharp rockers
As many call them-- junk Source heads ported
M1 manifold
1050 E85 Carb
8 3/4 REAR WITH 4.88 gears and a 28.5 x 11 Hoosiers slicks
Cal/Track system mono spring
4800 Stall Converter Trans brake leaving at 3800 rpm
BRACKET RACE CAR
CAR WEIGHS 3250
I have pounded this combo for 6 years.
Best ever ET 10.62 AT 128.1 MPH 1/4 and a 6.63 at 102.5 1/8th Differant tracks.This year!
I may have about 10 grand into the whole thing.
A buddie of mine has about the same combo and he is a touch faster in the 1/4 mile. We were talking last night and we were kidding around how much we don't have in these cars and how we are real close to the same ETs and Mph of guys that have 440 or 400s that are stroked out to 500 plus cubes.I gess I am a stone age mopar guy. Only because I can not afford to have a credit card race car.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Slow Mopars [Re: slippery440] #1152982
01/08/12 07:18 PM
01/08/12 07:18 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i never could get a good time on my heap. the sand keeps getting stuck in the hourglass.
Re: Slow Mopars [Re: lewtot184] #1152983
01/08/12 07:47 PM
01/08/12 07:47 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Don't have an ET on my sled yet but It's built as cheap as possible and runs very strong on the street. I hope to get some track time this spring...
67 Valiant, no heater/wipers, manual steering, aftermarket wiring
full interior
3100 with me in it and I'm 220
stock 67 318
GT45 turbo/air to air intercooler
homebuilt holley 650dp
old torker single plane
2800 converter and stock 904
3.55 gear and minispool
26-28" tires depending on what wheels I have on it
I built EVERYTHING myself in my gravel driveway with simple tools. I don't have a tubing bender or tig welder, nothing fancy. All the exhaust side was built with off the shelf bends cut with a sawzall...I don't even have a radial arm saw for precise cuts lol. I feel like when tuned, it should run 7.50-7.60's in the 1/8th on 12lbs boost and pump gas. With more boost and race gas it might manage low 7's. I have about $5000 in everything including the price of the car and building the rearend. I love the low buck cars that get it done. I don't have a 75k a year salary to spend I've got 30k, a morgage, and bills lol so everything has to be cheap and make the most power per dollar spent
Re: Slow Mopars [Re: SLOW67] #1152984
01/08/12 08:35 PM
01/08/12 08:35 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
I'm in the same boat..LOL, I make good money ,but every time I save
up some loot -something in my house break's or someone is worse off
than me ...so there it goes - race part's or food for kid's ? -
(not mine)I have 2 with 1 on the way,that have more than needed.
I had a whole turbo set up to mess around with ,and sold it cos
I figured I would never get if figured out with out spending a
ton of money,so It's just an
N/A 360,.030 over
10.5 KB 190
Isky 304 hyd stick/with solid lifter's(tight lash)
Crane roller's
Ported 587
M1 single,Demon 750/pro form main body
904 rev man valve body,3500 stall that's tired
8-3/4 ,4.10,28-13.50 tire
I'm kinda of at a loss as to what I'm going to do with the rear suspension...So I will just ask a bunch of dumb ? here and figure
it out.
Have a good winter stay warm.
Re: Slow Mopars [Re: slippery440] #1152985
01/08/12 08:46 PM
01/08/12 08:46 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
My JUNK
KB Hyper pistons
M1 manifold
1050 E85 Carb
BRACKET RACE CAR
CAR WEIGHS 3250
wow you win the junk and stuff key broad prize with that motor i dont think abody else wants one
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Slow Mopars [Re: WHITEDART] #1152986
01/09/12 11:30 AM
01/09/12 11:30 AM
Central New York
Crybaby440
Crybaby440
Central New York
My JUNK
KB Hyper pistons
M1 manifold
1050 E85 Carb
BRACKET RACE CAR
CAR WEIGHS 3250
I am proud of my junk. Paid for with real cash and does not blow up or burn down and will run the same number time after time. I have actualy won races with my junk and actualy beating faster mopars and chevy and fords that either have alot more cubes or high on nitrous. So what was your point? Better yet what is your pride and joy?
Re: Slow Mopars [Re: slippery440] #1152987
01/09/12 04:33 PM
01/09/12 04:33 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
My car:
1974 Dodge Dart Swinger 2dr 3300lbs race ready on line.
Flat top piston 440, zero decked, (11.25:1 compression) with ported 915 heads- Flow 268/207 peak. I run mopar 590 solid cam, M1 single plane intake, McCandless headers, 850HP carb./ 9.5 Dynamic converter (high gear flashes 5100)
Mopar Superstock leaf springs, clamped in rear with pinion angle set at 6.5 degrees nose down. Mopar long drag shocks in rear, 3 way Competition Engineerings in front. 6cyl Torsion bars / 30x9 Hoosier slicks. 4.30 rear gear
Bests for 2011 footbraking:
10.77 @ 122.8mph 1/4 mile Cedar Falls Raceway Sept 23
Incrementals:
1.47 60ft 6.80 1/8th @ 99.79 mph
Looking forward to this year!
Curator at Adams County Speed Shop
Re: Slow Mopars [Re: 340man4ever] #1152988
01/09/12 06:23 PM
01/09/12 06:23 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
i like combo posts like this.. i can feel ya on the low buck side of the story. it can get a lil depressing when you want to have a nice car but it just takes cash you AINT getting!
my junks not together but
74 dart sport all steel
440 cast crank ly rods
2295s mile down in the hole. nothings cut
stealth heads going to the porter soon
comp solid flat tappet 250 256 530 540 108
cheap deep pan, windage tray m1 or ??? intake
800holley DP 2 inch pro parts. 4000+ 9inch TCI 3.70 gear in ford 8.8
27 inch hoosiers would like some low 11's
Re: Slow Mopars [Re: shoebox] #1152989
01/09/12 06:58 PM
01/09/12 06:58 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Buddy's dart..
Cast iron head small block, no roller cam, no dominator carb, its no light weight either. mini tub'd 68 dart with cal tracks, and 28x10 tires...
Runs 9.90's and 10'ohs in the heat. No power adder's too, all motor..
3000 pound big block eater...
Re: Slow Mopars [Re: SLOW67] #1152990
01/09/12 08:28 PM
01/09/12 08:28 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
Mines a 79 360.030 over. Kb 10.5 kb piston, eagle rod stock crank, .525 hy comp cam. 8 1/4 rear with 4.10's with 28-10.5 et streets. Tagged tittled and insured.. 12.50's at 106.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Slow Mopars [Re: Bob_Coomer] #1152991
01/09/12 08:54 PM
01/09/12 08:54 PM
Central New York
Crybaby440
Crybaby440
Central New York
Buddy's dart..
All I can say is wow!!!!!
Proves that we can go fast with a good set up and not spend a fortune.
Re: Slow Mopars [Re: kissmyaspen] #1152992
01/09/12 08:58 PM
01/09/12 08:58 PM
Central New York
Crybaby440
Crybaby440
Central New York
My buddies car is a Aspen and they are not light ether. 12.50S Is a nice ET.
Re: Slow Mopars [Re: Bob_Coomer] #1152993
01/09/12 09:21 PM
01/09/12 09:21 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Buddy's dart..
What's the engine stroke/combo on that one?
Yeah, it's got a smallblock.
Re: Slow Mopars [Re: 340B5] #1152994
01/10/12 01:08 AM
01/10/12 01:08 AM
Amherst,NY
challengermike Offline
Amherst,NY
My last mopar was built cheaply and it did have a 440 stroked to 499
Cat crank and rods
kieth black forged pistons
weind team g intake
850 holley
comp xtreme engery cam 252 dur 540/555 lift
3,200 stall
3.91s
It was a fun street car that ran 7.6s in the 1/8
I had 10k into building the whole car including buying the car.
I did all the work myself and did alot of buying of used parts.
Went from this
Re: Slow Mopars [Re: challengermike] #1152995
01/10/12 01:10 AM
01/10/12 01:10 AM
Amherst,NY
Amherst,NY
to this
Re: Slow Mopars [Re: 340B5] #1152996
01/10/12 01:44 AM
01/10/12 01:44 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Buddy's dart..
Its a .100+ over 318 block, and a 4" stroke crank...
Compression is close to 13.5:1
I keep telling him to add a roller and dominator and that thing would pickup several tenth's. But e says he has to add a bunch more for tech too. I gotta agree, I have seen him run whole race weekends and never take a look under the hood.
Re: Slow Mopars [Re: Bob_Coomer] #1152997
01/10/12 04:15 AM
01/10/12 04:15 AM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
I have a 64 Plymouth 440 30 over stock stroke ly rods ross dome pistons solid cam ported 452 heads M-1 intake 950 holley 8-3/4 with 4.56s on super stock springs 30x9 slicks.Best et 10.86 123mph. Race weight 3680#. 5 years and counting.
Re: Slow Mopars [Re: Smoparmike] #1152998
01/10/12 04:59 AM
01/10/12 04:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont consider 10's slow at all. For the como's I see on here they run pretty good. My 63 is a street car with a 440 and 4.15 crank with Indy heads and a flat tappet cam. Indy dual plane intake and 850 DP. So far on 92 pump thru the pipes at 3700 lbs it run 10.76 @ 124.49. But I only have 7 passes on the eng so I hope to improve next year. Ron
Re: Slow Mopars [Re: Bob_Coomer] #1152999
01/10/12 05:05 AM
01/10/12 05:05 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
Buddy's dart..
That's straight impressive.
Re: Slow Mopars [Re: Bob_Coomer] #1153000
01/10/12 11:23 AM
01/10/12 11:23 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Buddy's dart..
What heads on this car? I know they are cast iron.....
Combo sounds super impressive!
