Oil pan gasket #115222
09/04/08 08:01 PM
09/04/08 08:01 PM
Nova Scotia Canada
Blue71 Offline OP
Blue71  Offline OP
Nova Scotia Canada
Hi
I just wasted a cork/rubber coated pan gasket from MP and a cork Fel-pro gasket. They seem to slide and tear at the front & rear bolt holes.Maybe to much silicone.
Does anybody make a one piece gasket for a 71/340.
Ken
Re: Oil pan gasket [Re: Blue71] #115223
09/04/08 11:54 PM
09/04/08 11:54 PM
i just bought a gasket from Summit that in some place is described as a reusable 1 piece but not always. I'll find out in 3 days.
pn DCC-4007572
Brand: Mopar Performance
Product Line: Mopar Performance Oil Pan Gaskets
Part Type: Oil Pan Gaskets
Part Number: DCC-4007572
Gasket Material: Rubber
Rear Main Seal Style: 2-piece
One Piece Gasket: No
Quantity: Sold as a set.
Notes: Reusable.
Oil Pan Gasket, Multi-Piece, Rubber, Dodge/Plymouth, 340, Set
Check to make sure this part fits your application
One-piece design to seal your engine.
Got a Mopar that needs an oil pan gasket? Mopar Performance has what you need. These oil pan gaskets are a one-piece design, to minimize the chances of leaks, and they're designed specifically for your engine by the company that made it in the first place. Note that you will need two of these gaskets if you are using a windage tray. One goes on each side of the tray.
Re: Oil pan gasket #115224
09/05/08 06:32 AM
09/05/08 06:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cork and silicone dont mix.Seen too many wanna bes use silicone with cork and other new gaskets.If the gasket dosent seal new you have a problem either over tightened or something not straight.Been doin this for over 40 years and I install almost everything dry.Rocky
Chrysler Firepower
Re: Oil pan gasket [Re: therocks] #115225
09/05/08 10:36 AM
09/05/08 10:36 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Silicone does make cork gaskets slide around. Glue them down next time. Mike
Re: Oil pan gasket [Re: mopars4ever] #115226
09/05/08 10:43 AM
09/05/08 10:43 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
The description makes no sense at all. In the specs it says its not a one piece. The text below says it is. They talk in the text about needing two gaskets for a windage tray. Thats only with big blocks....
Re: Oil pan gasket [Re: Blue71] #115227
09/05/08 07:56 PM
09/05/08 07:56 PM
Nova Scotia Canada
Blue71 Offline OP
Blue71  Offline OP
Nova Scotia Canada
Hi
Thanks for the info.I will try another from MP without the silicone and see what happens .
Thanks Again
Ken
Re: Oil pan gasket [Re: Blue71] #115228
09/05/08 09:02 PM
09/05/08 09:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
small dabs in the corners
