i just bought a gasket from Summit that in some place is described as a reusable 1 piece but not always. I'll find out in 3 days.
pn DCC-4007572
Brand: Mopar Performance
Product Line: Mopar Performance Oil Pan Gaskets
Part Type: Oil Pan Gaskets
Part Number: DCC-4007572
Gasket Material: Rubber
Rear Main Seal Style: 2-piece
One Piece Gasket: No
Quantity: Sold as a set.
Notes: Reusable.
Oil Pan Gasket, Multi-Piece, Rubber, Dodge/Plymouth, 340, Set
Check to make sure this part fits your application
One-piece design to seal your engine.
Got a Mopar that needs an oil pan gasket? Mopar Performance has what you need. These oil pan gaskets are a one-piece design, to minimize the chances of leaks, and they're designed specifically for your engine by the company that made it in the first place. Note that you will need two of these gaskets if you are using a windage tray. One goes on each side of the tray.
