Need B-1 orginal pistons #1152088
01/07/12 10:24 AM
01/07/12 10:24 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Need a new set of pistons. Long story short my machine shop put to much clearance in my block for my pistons. Now I'm going to have to fit a piston to the block. Where have you found the best value for customs?
Mark
Re: Need B-1 orginal pistons [Re: mac56] #1152089
01/07/12 11:30 AM
01/07/12 11:30 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Diamond .
Re: Need B-1 orginal pistons [Re: mac56] #1152090
01/07/12 11:35 AM
01/07/12 11:35 AM
Delray beach, Florida
P
Performance Only Offline
P
we're a distributor for Diamond pistons and have spec'd a lot of B-1 customs. let me know if i can help.
machine shop owner and engine builder
Re: Need B-1 orginal pistons [Re: Performance Only] #1152091
01/07/12 11:39 AM
01/07/12 11:39 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
What size are your old ones? What combo? New? You may could recoupe some bucks selling them.
Re: Need B-1 orginal pistons [Re: Mopar-Al] #1152092
01/07/12 12:19 PM
01/07/12 12:19 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
My block was supposed to be 4.375 and the machinist honed it to 4.380 so I have .013 clearance already
Re: Need B-1 orginal pistons [Re: mac56] #1152093
01/07/12 12:37 PM
01/07/12 12:37 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Man, seems that could have been avoided. Did he have the pistons at the time of the machine work? Why should you pay for HIS mistake? Atleast from my view, I would ask for compensation.
Re: Need B-1 orginal pistons [Re: Bob_Coomer] #1152094
01/07/12 01:18 PM
01/07/12 01:18 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
He had the pistons and the paper work from Ross. This engine ran this year and the mistake was not found until it was taken apart for inspection so compensation won't happen. I fault myself for not checking the work on assembly.
Re: Need B-1 orginal pistons [Re: mac56] #1152095
01/07/12 03:11 PM
01/07/12 03:11 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
As I recently found out, B1 pistons are custom only and was told there is no off the shelf piston made.. I got a quote from JE Pistons of $80.00 per, plus the cost of the pin.... however I doubt this to be true as I have found every other custom made piston to be over $100 per..
So if anyone would post some prices, I'm sure it will be helpful to a lot of people here..
Re: Need B-1 orginal pistons [Re: Jeepmon] #1152096
01/07/12 04:30 PM
01/07/12 04:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You dont wanna know what mine cost
Re: Need B-1 orginal pistons [Re: Al_Alguire] #1152097
01/07/12 04:37 PM
01/07/12 04:37 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Can you have them coated? Not sure how thick coating is but it may help.
Re: Need B-1 orginal pistons [Re: abodiesonly1] #1152098
01/07/12 04:41 PM
01/07/12 04:41 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
When I looked into having my pistons coated.. I think the coating is good for .002 per side which will only be .004 total... and there's nothing to prevent the coating from scratching off..
Re: Need B-1 orginal pistons [Re: Al_Alguire] #1152099
01/07/12 04:42 PM
01/07/12 04:42 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Al.. you should know by now.. I live my fantasy life thru you..
Re: Need B-1 orginal pistons [Re: Jeepmon] #1152100
01/07/12 05:08 PM
01/07/12 05:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I think I paid around 100 dollar and have my old 440-1 pistons valve reliefs cut so I could either use my 440-1 heads or my B1 heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need B-1 orginal pistons [Re: mac56] #1152101
01/07/12 05:09 PM
01/07/12 05:09 PM
Super Scamp Offline
Super Scamp  Offline
I would have you manchinest pay for it. Call Best Machine they can get any B1 piston you may need.
Just One Man's Opinion Mopar Mafia Racing
Re: Need B-1 orginal pistons [Re: Jeepmon] #1152102
01/11/12 01:08 PM
01/11/12 01:08 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
The good coatings are only good for about .0005" on each side.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Need B-1 orginal pistons [Re: 23T Hemmee] #1152103
01/11/12 02:50 PM
01/11/12 02:50 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
http://www.swaintech.com/store.asp?pid=10964
PC-9™ is commonly used to salvage a motor that has excessive piston to wall clearance. Vintage motors and other applications with hard to find pistons can
have up to .004” of PC-9™ added to the diameter of a piston to tighten piston to
wall clearance.
Re: Need B-1 orginal pistons [Re: Jeepmon] #1152104
01/11/12 06:36 PM
01/11/12 06:36 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I spoke with diamond this morning and I think I have narrowed my choice to roughly 6.535 rod and 1.35 piston or 6.385 rod and 1.50 piston.
Re: Need B-1 orginal pistons [Re: mac56] #1152105
01/11/12 10:17 PM
01/11/12 10:17 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Just My
go with the longer rod. It will make the piston much lighter, and the rods are common too.. Its your typical +.400 Chevy rod used in lots and lots of combo's.
Re: Need B-1 orginal pistons [Re: Bob_Coomer] #1152106
01/12/12 02:48 AM
01/12/12 02:48 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have generally always gone with the 6.53" rod in that application. i like ot keep the bobweight as light as possible in a stock block deal for sure.
Re: Need B-1 orginal pistons [Re: mac56] #1152107
01/12/12 03:28 AM
01/12/12 03:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What diameter pistons... I have a new set of b-1 m/c
pistons for a 4.440 bore that will be for sale
also what compression
