Re: Need B-1 orginal pistons
[Re: Bob_Coomer]
#1152094
01/07/12 01:18 PM
01/07/12 01:18 PM
Posts: 976 ontario canada
mac56
ontario canada
My block was supposed to be 4.375 and the machinist honed it to 4.380 so I have .013 clearance already
Man, seems that could have been avoided. Did he have the pistons at the time of the machine work? Why should you pay for HIS mistake? Atleast from my view, I would ask for compensation.
He had the pistons and the paper work from Ross. This engine ran this year and the mistake was not found until it was taken apart for inspection so compensation won't happen. I fault myself for not checking the work on assembly.
[Re: abodiesonly1]
#1152098
01/07/12 04:41 PM
01/07/12 04:41 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Can you have them coated? Not sure how thick coating is but it may help.
When I looked into having my pistons coated.. I think the coating is good for .002 per side which will only be .004 total... and there's nothing to prevent the coating from scratching off..
[Re: Al_Alguire]
#1152099
01/07/12 04:42 PM
01/07/12 04:42 PM
Jeepmon
Sunnyvale, CA
You dont wanna know what mine cost
Al.. you should know by now.. I live my fantasy life thru you..
[Re: mac56]
#1152101
01/07/12 05:09 PM
01/07/12 05:09 PM
Posts: 694 Michigan
Super Scamp
I would have you manchinest pay for it. Call Best Machine they can get any B1 piston you may need.
Just One Man's Opinion
Mopar Mafia Racing
[Re: 23T Hemmee]
#1152103
01/11/12 02:50 PM
01/11/12 02:50 PM
Jeepmon
Sunnyvale, CA
The good coatings are only good for about .0005" on each side.
http://www.swaintech.com/store.asp?pid=10964
PC-9™ is commonly used to salvage a motor that has excessive piston to wall clearance. Vintage motors and other applications with hard to find pistons can have up to .004” of PC-9™ added to the diameter of a piston to tighten piston to wall clearance.
[Re: Bob_Coomer]
#1152106
01/12/12 02:48 AM
01/12/12 02:48 AM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
I have generally always gone with the 6.53" rod in that application. i like ot keep the bobweight as light as possible in a stock block deal for sure.
[Re: mac56]
#1152107
01/12/12 03:28 AM
01/12/12 03:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What diameter pistons... I have a new set of b-1 m/c pistons for a 4.440 bore that will be for sale also what compression
