Page 2 of 3 1 2 3
Re: A500 vs. Gear Vendors [Re: NicksGarage] #1151154
01/07/12 12:57 AM
01/07/12 12:57 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Re: A500 vs. Gear Vendors [Re: Dragula] #1151155
01/07/12 01:03 AM
01/07/12 01:03 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Curious about thoughts on how much impact reducing engine rpm from 3100rpm @ 70mph (std 727 trans) vs 2550rpm @ 70 mph (with Gear Vendors) would have on the a 6.1 L hemi
Mileage?
Wear and tear?
Noise?
Other thoughts?
-C
Re: A500 vs. Gear Vendors [Re: NicksGarage] #1151156
01/07/12 01:18 AM
01/07/12 01:18 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The GV unit will take 0hp away from your normal 3 speed operation where as the A500 is always robbing some hp because it drives thru the OD all the time. They say it can rob as much as 1sec in ET...
I have never seen one scrap of evidence to back up this claim. Not saying it's impossible, but I have never seen anything to substantiate this at all. Until I see a real, all things equal comparison between the two, I'm going to have to put this one right up there with the other myths like the thin wall 70's 440 blocks and low nickel late 70's mopar blocks.
Before I committed to it I asked around if this transmission would be a good choice for a motorhome (weighs 6500 pounds) and was told that the overdrive part would be too weak for this application. I ended up just building a standard 727. I would have liked the extra mileage. Now I have a new '74 camper which is around 7000 pounds and interested in overdrive again but this rig already has a good 727 in it and wonder if this shortie overdrive would work.
So they didn't think the 518 would work in a 6500-7000lb motor home but it works just fine in dodge pickups that weigh 5000lbs on their own + tow that much in trailers, cars, campers, etc. A good rebuild kit and the transgo tfod-hd2 shift kit is the ticket. With the right combination of parts you can also install extra clutches in the overdrive tail unit.
Re: A500 vs. Gear Vendors [Re: DaytonaTurbo] #1151157
01/07/12 01:25 AM
01/07/12 01:25 AM
South Dakota
W
wireweld Offline
wireweld  Offline
W
South Dakota
smr transmissions did a comparison on a small block dodge dakota between a 727 and a 518. Lost a full second e.t. with the 518. Same truck, engine, rear and track.
Re: A500 vs. Gear Vendors [Re: Dragula] #1151158
01/07/12 02:39 AM
01/07/12 02:39 AM
BDW Offline
BDW  Offline
Here is the shorty..
http://smrtrans.tripod.com/smrtransmissionsintro/id32.html
THE "Shortie" overdrive option can be added to any of the above transmission models for the additional cost of $2,825.00.
I just lost interest!
Re: A500 vs. Gear Vendors [Re: BDW] #1151159
01/07/12 03:59 AM
01/07/12 03:59 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Yeah it would take a lot of miles for me to pay for that in gas savings. I almost bought a Class C motorhome for $1500 that had a gearvendor in it. This was before I got my own motorhome so I would have had to figure out what to do with the rest of it. It wasn't a bad motorhome just a lot bigger than I wanted.
Re: A500 vs. Gear Vendors [Re: wireweld] #1151160
01/07/12 04:04 AM
01/07/12 04:04 AM
Manitoba, Canada
Manitoba, Canada
I'm sure a company that specializes in 727 and 904 AND sells the gear vendors units is absolutely unbiased.
Where's the data? Specs on the transmission builds? Was this a bone stock w/ stock converter 518 left in drive versus a 727, converted to roller internals with an aftermarket converter, valve body and shifted manually?
Take a stock unrebuilt 727, stock unrebuilt non-lockup 518(so you can put the same converter on both) and actually rebuild both transmissions COMPARABLY. Then run then down the track 10 times each and get back to me. Until someone does that, everything is heresay and myth.
Re: A500 vs. Gear Vendors [Re: dfsmopars] #1151161
01/07/12 06:56 PM
01/07/12 06:56 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If the GV overdrive had the same overdrive ratio, I would possibly consider it.
But at 15000 miles a year with 20 miles to the gallon and gas at 6 dollars a gallon, the break even point for the GV at $3k would be over three years.
Since most of us are not going to get 20 mpg and we will drive less than 15000 and hopefully gas does not make six dollars, payback will be even further into the future. The A500 at half the price and better ratio makes better sense to me.
Re: A500 vs. Gear Vendors [Re: denfireguy] #1151162
01/07/12 08:25 PM
01/07/12 08:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 518 can in no way rob more HP than a GV. The 518 only adds roteing weight in 1st 2nd and 3rd, no other "drag" is added, the pump is not doing any work holding clutches or bands or line preasure or any thing. The GV adds a similar amount of rotateing weight in all gears combined with an almost useless extra gear. The OD section can easily have clutches added, if you use the 48RE OD section it can handle 800 lbs tq easily!
As for the 1 second difference in ET from a 727 to a 518 I say BULL CRAP! Like I mentioned earlier, there is a few pounds added to the rotateing weight, thats IT! In first second and third there is some extra weight and in no way can those few extra pounds knock off 1 second in ET. If the trannys get equal prep it can't be more than a couple tenths. If 5-10 pounds in rotateing weight could really knock off 1 second then every car could switch from a steel drive shaft to carbon fibre and gain a second
Re: A500 vs. Gear Vendors [Re: HotRodDave] #1151163
01/07/12 08:50 PM
01/07/12 08:50 PM
Its funny the people commenting on the facts when they don't own or drive either of them...Where are your "facts"? The fact that most seem to agree upon is that neither are are cheap, and I can say if you skimp on an A500 rebuild, it will come back out when it does start slip.
Re: A500 vs. Gear Vendors [Re: DaytonaTurbo] #1151164
01/07/12 10:08 PM
01/07/12 10:08 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yeah, I'm calling shenanigans on this claim, too...especially when a mid-late 90's dak with a 318 and a few bolt on's is a high 13 second ride....I can't see swapping from a 518 to a 727 or 904 getting it into the 12's.
granted my 5th ave is a mild build, at the time a XE262,header, and RPM air gap equipped 360 long block, but I saw no appreciable difference going to a 904 with a MP166K converter and B&M trans pack shift kit to a A500 with the same converter and trans go TFOD shift kit.
2017 Grand Cherokee Overland
Re: A500 vs. Gear Vendors [Re: patrick] #1151165
01/07/12 10:20 PM
01/07/12 10:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have run both the A518lu and the 727 in my 410 stroker truck and haven't found 2 tenths difference using the same stall rated coverter (3000)and rear end. Launching and shifting both at the same RPM. That's facts.
Re: A500 vs. Gear Vendors [Re: HotRodDave] #1151166
01/08/12 12:37 AM
01/08/12 12:37 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Show us the math on the "worthless extra gear". I'll even give you the parameters. 3.73 rear gear, 28" tall rear tire, 4000lb car.
Also has anyone factored the cost of modifying the trans tunnel or the loss of perceived value with a hacked up cross member?
Re: A500 vs. Gear Vendors [Re: ramman5600] #1151167
01/08/12 01:08 AM
01/08/12 01:08 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the worthless extra gear comment meaning this:
3rd (direct) at 75mph with 28" tires and 3.73 assuming no converter slip: 3350 RPM, mist likely 3500 w/converter slip
gear vendors OD drops it to 2650 RPM no converter slip, most likely 2800-2850 with slip
518 OD drops it to ~2320 RPM, with no converter slip. you won't have converter slip if using a lockup converter...
IMHO a .78 OD is not enough OD to warrant the cost...
Re: A500 vs. Gear Vendors [Re: patrick] #1151168
01/08/12 01:14 AM
01/08/12 01:14 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
IMHO a .78 OD is not enough OD to warrant the cost... [/quote}
Cost aside - 700 rpm drop is not worthless. The 518 is better from that standpoint, but what option do you have if you don't want to hack up your car? Keisler GM adaptation? Better first ratio and as good or better O/D ratio.
Re: A500 vs. Gear Vendors [Re: ramman5600] #1151169
01/08/12 01:15 AM
01/08/12 01:15 AM
Manitoba, Canada
Manitoba, Canada
Well if you can't manage the tunnel/crossmember mods yourself, then chances are you can't fab your own trans mount for the 518, and chances are you can't build your own 518 either. So if you have to farm all that out, you are probably at the same $ level as a gear vendors.
FWIW, the OP asked about a 72 charger. A 72 charger will not need the tunnel or crossmember modded. A 70 or earlier b-body would need those mods. If you have a car that would need the crossmember modded, and you're not comfortable with that, then yes chances are you would be happier with a gear vendors or a chevy 700r4 based auto like the keisler 4-sp auto. Also, from what I've gear, the gear vendors units still do require you to your tunnel for clearance. You don't have to and but it's not a straight bolt in either from what I've read.
Re: A500 vs. Gear Vendors [Re: ramman5600] #1151170
01/08/12 01:16 AM
01/08/12 01:16 AM
Manitoba, Canada
Manitoba, Canada
IMO it is worthless when you consider a comparable or lesser cost option like a 500/518 or chevy 700r4 will deliver a much superior overdrive ratio.
Re: A500 vs. Gear Vendors [Re: DaytonaTurbo] #1151171
01/08/12 11:23 AM
01/08/12 11:23 AM
South Dakota
W
wireweld Offline
wireweld  Offline
W
South Dakota
What about the 200r4? Same ratio as the 904 w/low gear set and a nice .67 od. Can handle a good amount of power when built right. And no tunnel mods, just need to redo the cross member.
Re: A500 vs. Gear Vendors [Re: wireweld] #1151172
01/08/12 11:44 AM
01/08/12 11:44 AM
the house on the left.
cogen80 Offline
cogen80  Offline
200r. supposed to fit with no cutting the floor too. i want to see what this guy has to do to get it in his car. sounds like a decent option though. http://www.forabodiesonly.com/mopar/showthread.php?t=169183&highlight=200r4
Re: A500 vs. Gear Vendors [Re: dfsmopars] #1151173
01/08/12 11:53 AM
01/08/12 11:53 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I would add Gear Vendors for one simple reason. I don't think MYSELF would change an original part of my car, just making upgrades. Gear Vendor is an upgrade of the original part, is an ADD ON section on my original tranny.
Otherwise, I think there is not 727 replacements with OD for BBs... or yes ?
But that's me
anyway, I can't afford it LOL
Page 2 of 3 1 2 3
