New Distributor gear needed for LA to Magnum swap? #1150844
01/05/12 02:08 PM
01/05/12 02:08 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Is it necessary to change the distributor gear when using an LA dizzy in a roller lifter Magnum engine?
Re: Distributor gear for LA to Magnum swap [Re: Rosco] #1150845
01/05/12 02:32 PM
01/05/12 02:32 PM
Andrewh Offline
Andrewh  Offline
bottom of the distributers look the same to me.
so I cannot see why you would need to change.
Re: Distributor gear for LA to Magnum swap [Re: Andrewh] #1150846
01/05/12 03:46 PM
01/05/12 03:46 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Let's see what the big kids say, but we didn't.Same drive shaft out of the old LA (we didn't get one with the mag)
The Hydro Roller stock cams (I was TOLD)
are still just cast, only need that sacrificial bronze gear deal with a billet solid roller
(a REAL mans cam )
just kidding, I have zero roller stuff, can't afford.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: Distributor gear for LA to Magnum swap [Re: Sixgun] #1150847
01/05/12 04:49 PM
01/05/12 04:49 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
I was told that I didn't need to change it either,but it's better to have more than one opinion.
Re: Distributor gear for LA to Magnum swap [Re: Rosco] #1150848
01/05/12 06:57 PM
01/05/12 06:57 PM
scratchnfotraction Offline
no need to swap them,they are the same.
the old la dist drops right in a magnum engine.
on the stock SB roller cams and my lunati SB roller cam it has a cast iron gear/ring pressed on to the steel cam core so a bronze gear is not needed.
not all roller cams are like this,IIRC the BB do not get the cast ion gear on the core so a bronze gear is needed.
Re: Distributor gear for LA to Magnum swap [Re: scratchnfotraction] #1150849
01/05/12 07:17 PM
01/05/12 07:17 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
"on the stock SB roller cams and my lunati SB roller cam it has a cast iron gear/ring pressed on to the steel cam core so a bronze gear is not needed." This is not the case.The stock cores are NOT 2 pc,just a cast cam. Many cams from Comp,Lunati and others are cast cores,not 2pc. It's not a big deal.
Re: Distributor gear for LA to Magnum swap [Re: goldmember] #1150850
01/05/12 08:44 PM
01/05/12 08:44 PM
thats just what they told me when i bought mine,you can clearly see a cast iron ring on my lunati,it has a parting line and is a blue gun metal color while the cam core is shinny chrome looking.
but then again I have been wrong before
