Re: Hydraulic throwout bearing kits
[Re: Commando1]
#1150377
01/10/12 04:13 PM
01/10/12 04:13 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
IN your original design that you made the bracket for, did you say there as a version with the bleeder on top?
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#1150378
01/10/12 08:04 PM
01/10/12 08:04 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Yes, I remember coming across one but darn it if I can remember what the app. was. Sorry.
[Re: sshemi]
#1150381
06/12/13 04:42 PM
06/12/13 04:42 PM
Posts: 181 Washington State
70chall440
Washington State
What do you mean by adj a hyd bearing? If you install it correct you should never need to adj again
what I meant was that in some Hyd systems you have to adjust the spacing of the TB with relation to the PP which is difficult to do outside of the car. Also, bleeding an enclosed system can be a challenge.
01 Viper GTS ACR 10 Challenger RT PCP 6spd 70 Challenger 440 6 pac 73 Cuda 416 Road Racer 70 Hemi Roadrunner 01 Ram 4x4 / 98 Ram 3500 91 Stealth RT 05 Durango Hemi 09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
[Re: Red383]
#1150384
06/13/13 10:08 AM
06/13/13 10:08 AM
Commando1
I think this is the application: 1990 Nissan 300ZX
Commando, how did you handle the contact point of the slave cyl push rod to the clutch fork?
Can someone tell me if the Throwout bearing should contact the fingers on the pressure plate, or should there be an air gap between them?
I replace the slave's push rod with Grade 5 threaded rod (very hard to find) and used the nut, washer, grommet, spring, and clip/washer out of a regular clutch adjuster kit. For the end of the threaded rod that goes into the slave, I ground it to a smooth round tip.
The T.O. bearing should have a .010 gap between it and the fingers on the clutch.
It CAN'T be done out of the car.
also, bleeding an enclosed system can be a challenge.
No. It's as simple as bleeding brakes. Easier, in fact.
[Re: a12superbee]
#1150385
06/13/13 12:17 PM
06/13/13 12:17 PM
Posts: 15,487 Florida
scratchnfotraction
Good info here, I'm glad it got bumped up.
I want to figure out if there is an adaptor to mate the stock hydro bell to the BB engine.
I converting my truck to 5 speed with this v-6 hydro bell with the A535 trans.
seems they hook a 904 to a Bb so a SB bell should be able to adapt maybe??
[Re: scratchnfotraction]
#1150387
06/13/13 12:28 PM
06/13/13 12:28 PM
scratchnfotraction
this 5 speed replaced the a535 and it should also bolt in where a 833/833OD fits with floor pan/crossmember change to go hydro clutch with stock mopar parts.
#1150388
06/13/13 12:35 PM
06/13/13 12:35 PM
scratchnfotraction
this truck v-6 bell has 2 trans bolt patters looks like the a535 trans has the same bolt patter as a 883/833od or the new granny 4-5 speeds. you can even move the slave to pass side for more header/starter/exhaust room. If I can not get this to bolt to a BB,then maybe I can fab a slave like commando on a RB bell and fit the 5 speed to it in place of the 833/833od trans. anyone got a like to SB to BB adaptors??
