Axles B Body #1150178
01/04/12 01:06 AM
01/04/12 01:06 AM
NY
Beep Beep Offline OP
NY
I am building a stroker engine that should make 500hp and 550torque. I upgraded my posi unit with an auburn and a new 3:91 gear set. The car is only used for the street. Do I need to upgrade the original stock axles? They looked okay when I pulled them except for a small chip on one of the splines.
Re: Axles B Body [Re: Beep Beep] #1150179
01/04/12 01:10 AM
01/04/12 01:10 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
The stock axles will be fine if you aren't launching at 5000rpm with slicks.
The UPGRADED Auburn unit will smoke itself long before the stock axles give up ...
Re: Axles B Body [Re: Beep Beep] #1150180
01/04/12 01:11 AM
01/04/12 01:11 AM
Texas
440maxwedge Offline
440maxwedge  Offline
Texas
Well, I can tell you that with Moser Axles being as affordable as they are, why take the chance. They usually break at the step just up from the splines. I broke mine with a stock max wedge on drag radials, installed the Moser's and no more breakie breakie. I also installed them in my 70 Chally with a small block magnum crate. I say Moser or another alloy axle of your choice....
Re: Axles B Body [Re: 440maxwedge] #1150181
01/04/12 03:11 AM
01/04/12 03:11 AM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I think I'd change them to aftermarket just to be on the safe side.
When I last saw my Dentist for a chip in my tooth, he kinda grinned and said, "That's gonna be expensive....and time consuming too."
Re: Axles B Body [Re: aquamist60] #1150182
01/04/12 08:16 AM
01/04/12 08:16 AM
NY
NY
If I do decide to replace them. Which ones work with the stock drums and brakes? Moser, Strange, Mancini, Dr Dif? What length do I need for a 69 Roadrunner. Was the original ones 30 spline? My left side wheel studs are left hand nuts, I guess I will loose that.
Re: Axles B Body [Re: Beep Beep] #1150183
01/04/12 11:45 AM
01/04/12 11:45 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock what you are looking for, and I ship to Canada via USPS Priority Mail, daily.
Please E-mail me if you are interested.
Re: Axles B Body [Re: DoctorDiff] #1150184
01/04/12 11:57 AM
01/04/12 11:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I got mine from Doc. Good price and quick shipping. You upgraded the pumpkin right? If you go to the track at all it might be worth it. I plan on beating mine routinly so I upgraded.
Coming soon!!!!
Re: Axles B Body [Re: Beep Beep] #1150185
01/04/12 12:19 PM
01/04/12 12:19 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Depends on your tires. Street tires won't hook that much power so you won't load the axles that much. with slicks or the sticky DOT race tires, the stronger axles may be a good upgrade.
Re: Axles B Body [Re: 451Mopar] #1150186
01/04/12 09:11 PM
01/04/12 09:11 PM
NY
NY
I am running a bf radial ta 275/70r/15 in the rear, and the car will never see a drag radial or slick.
Re: Axles B Body [Re: Beep Beep] #1150187
01/06/12 09:08 PM
01/06/12 09:08 PM
NY
NY
Mr.Yuck, Yes the pumpkin is the original 489 with an upgraded yoke with U-bolts, and a motive 3:91 gear with timken bearings.
Re: Axles B Body [Re: Beep Beep] #1150188
01/06/12 11:13 PM
01/06/12 11:13 PM
Take the time now to replace the stock crush sleeve, if you haven't already, with a pinion spacer before you ruin the rear end
Re: Axles B Body [Re: Cab_Burge] #1150189
01/06/12 11:49 PM
01/06/12 11:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Did that too. Great piece. I also used the moroso billet caps instead of the U-bolts. Kinda a PITB but hey they are strong right???
Re: Axles B Body [Re: Mr.Yuck] #1150190
01/07/12 11:42 AM
01/07/12 11:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do agree upgrading the axles is a good idea. But with that said I still have the stock axles in my 63. I mostly drive the car on the street but I race it 2 or 3 times a year. I had a 500 hp 440 in it running mid 11's since 2006 and put my 600 hp 493 in this year and have made 7 passes so far running in the 10.70 area with no trouble. But I am lucky so far as I am asking for trouble if I dont upgrade my axles real soon. I will have to get a price from Dr diff. But if you are not racing and not putting sticky tires on it you can drive around on the stock axles. But as was said it wont hurt at all to upgrade the axles.
Re: Axles B Body [Re: 383man] #1150191
01/09/12 09:23 PM
01/09/12 09:23 PM
NY
NY
Do I need to remove the thrust washer from the posi unit?
Re: Axles B Body [Re: Mr.Yuck] #1150192
01/09/12 11:41 PM
01/09/12 11:41 PM
U.S.S.A.
U.S.S.A.
Those billet caps suck , you run the potential of locking up the driveshaft if the rear goes to just the right angle , they are too tall , U bolts would be better .
