ignition problem #1150031
01/03/12 07:11 PM
01/03/12 07:11 PM
california u.s.a.
racecar43 Offline OP
california u.s.a.
I have a problem I believe to be ignition a month or so my car started pinging and missing at about 5000 rpm up I've changed complete ignition from molar to msd and I can't get the timing set I run 34 total if I set it at that the car sounds retarded if I go higher it pings can anyone help ...
Re: ignition problem [Re: racecar43] #1150032
01/03/12 09:00 PM
01/03/12 09:00 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
not to be mean but wow that post is painful to read it sure would be great if you used punctuation see its alot easier to type this way but it sure is alot harder to read dont you think
It's Swifty! Swifty, you toad sucker!
Re: ignition problem [Re: racecar43] #1150033
01/03/12 09:10 PM
01/03/12 09:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
have you looked into a fuel issue?
Re: ignition problem [Re: racecar43] #1150034
01/03/12 09:41 PM
01/03/12 09:41 PM
What eng? No changes right before the prob started. Only pings/misses at 5K up at WOT? Put the timing back to where it was OK before & might T into the fuel line at the carb inlet and run a neoprene line to a round vac gauge (most have a psi side) taped to your windshield & take it back out & see if you have several psi @5000 rpm & I'm assuming it's acting up at WOT. If good there holler back
Re: ignition problem [Re: RapidRobert] #1150035
01/04/12 12:07 AM
01/04/12 12:07 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
...timing chain skip tooth?
Rick
