Re: rons fuel injection
[Re: slomoshun]
#1148645
01/02/12 07:06 PM
01/02/12 07:06 PM
Posts: 2,864 IN
Irun5snd8th
IN
Cant tell you exactly but mine are pretty tiny (like .020 or so)and I believe there are 4 of them two shooting to the front and two to the back. This is all by memory though. The valve controls how much fuel goes in. So as long as you are close you should be OK. I actually drilled and tapped my intake to accept it and did away with the plate because of hood clearance issues.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#1148646
01/02/12 08:11 PM
01/02/12 08:11 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
When cold pour some gas in the injectors and it will crank fine,after its warm it takes a little getting use to but you can still crank it. Or drill a hole in the intake and tap it for a Holley jet to inject gas into the engine on start up.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: slomoshun]
#1148649
01/02/12 09:49 PM
01/02/12 09:49 PM
Posts: 16,928 NC
440Jim
NC
I love the Ron's primer plus system with the spray bar. It starts great, builds heat with the gasoline tank, and drives in the pits on gas saving alcohol, clean oil, keeps heat in the motor, etc. I don't have exact measurements but the holes are tiny for a better spray at idle and low throttle driving in the pits, maybe 0.020" dia. The Ron's plate I have has 4 or 6 holes (I forget) spraying slightly up to mix with the incoming air. The adjustable needle valve is easy to set. Larger holes will be fine for priming, but not as good for idling and driving in the pits (poor spray, more like hose). IMO, buy the Ron's system. But if you must experiment... at least use their plate spray bar and put the rest together yourself if you feel like it. Quote:
i am going to use a nitrous spray bar i already have the holes in it are approx .035 and there r 8 holes
If you want to try that plate, plug all but 4 holes, IMO. The Ron's system uses a pump with 3-6 psi, and then the needle valve to reduce it futher (much further, IMO). Don't forget the solinoid valve to shut off the primer lines and prevent siphoning when running on the main fuel system. Check out the needle valve from McMaster-Carr #46425K11 (1/8 NPT) two way.
[Re: 440Jim]
#1148650
01/03/12 03:21 AM
01/03/12 03:21 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
I made my spray bar and drilled 4 holes at.040" in the 1/8" tube. Cheapo mr gasket electric street pump, a used nitrous fuel solenoid from a swap meet, a parker flow control (make sure to plumb it the right direction DAHIK), a jr dragster fuel cell, and a 3 position switch (momentary-off-on). Wish I would have done this when I put the toilet on, not a year later. Hope this helps, Beep
[Re: Bigbeep]
#1148651
01/03/12 03:27 AM
01/03/12 03:27 AM
Posts: 2,513 PA
moparacer
PA
I use it on my car to start and build heat.
I left the gas system on my car and just bought the plate off of James.
I think mine has 6-8 holes in it and they are very small.
Maybe .015-.020 or so but never measured them.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: jafr]
#1148654
01/04/12 07:45 PM
01/04/12 07:45 PM
Posts: 2,864 IN
Irun5snd8th
IN
May be in the tune but I find I can heat mine up faster with barrel valve half shut and then just cracking the throttle thus causing it to sound like it dies. Warming it at the beginning of the day completely up on gas I think causes two issues. One it heats the engine up faster than the other components like the tranny and rear end. And the other is the spark plug situation. Didnt change my plugs the entire year. And here is the thing that really shocked me. I used SUBSTANTIALLY less alcohol this year on the fuel injection than I have in previous years. To the tune of about 3-4 barrels less for the same amount of runs. Again I only use the primer to get it out of the trailer and back in the trailer and a squirt to start the car. Thats it! Double entered at Chandler where my pit was on the front row (basically the return road) I made 13 passes on 12 gallons of Alky. And since I was doubled I was not pulling the barrel valve halfway shut coming up the return road either. So much for the fuel injection eating tons of fuel theory.
[Re: Irun5snd8th]
#1148655
01/04/12 10:16 PM
01/04/12 10:16 PM
Posts: 16,928 NC
440Jim
NC
I used the shut off valve almost closed (not the barrel valve) to heat and drive in the pits on alcohol for years. That technique works, just takes a few times to get used to since if you go to far the engine dies from fuel shut off. If you are having issues with running on gas, I would try adjusting the gas mixture with the needle valve. But every combo could be different.
But I have saved more fuel using the Ron's primer plus. Since I was running E85, I used the same fuel and tank for both the main and primer systems (E85). The use of the primer plus is easier (but the shut off valve trick is not hard), and I cut my fuel consumption by 10%-15% compared to the leaning with the shut off valve. When running mechanical injection with alcohol, you can burn more alcohol driving to & from the pits then going down the track if you don't take some precautions. Not to mention the proper tune.
[Re: 440Jim]
#1148656
01/04/12 11:18 PM
01/04/12 11:18 PM
Posts: 2,864 IN
Irun5snd8th
IN
Should have said shutoff cable which controls the shutoff on the barrel valve. Mine will run fine on the primer around the pits, I just have better luck using the "shutoff".
