Torsion bar #1148218
01/01/12 07:09 PM
01/01/12 07:09 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
Can you raise the front end (turn torsion bar adjuster CW) with the tires on the ground, or will it snap the bolt? I started to do this and then realized something was going to give. I'm wondering if I weakened the adjuster bolt.
Re: Torsion bar [Re: Moparmaniacc] #1148219
01/01/12 07:15 PM
01/01/12 07:15 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I don't know if it's the recommended way to do it but that's how I've always set the ride height on mine. I do use a long-handled ratchet and not an air wrench (don't think it would fit anyway) and spray the threads with penetrating oil.
Edit: Just looked in my old Chiltons Manual and that's the way they describe doing it.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Torsion bar [Re: I_bleed_MOPAR] #1148220
01/01/12 07:24 PM
01/01/12 07:24 PM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
Yup.... spray the adjuster bolts with good penetrating oil and let sit a while 10-15 mins..Get a good deep well 6 point socket and rachet or I use an impact wrench after the penetrating oil works a bit. It is much faster as long as you raise each side up a little at a time. Works every time!
HR 20
Re: Torsion bar [Re: Moparmaniacc] #1148221
01/01/12 08:19 PM
01/01/12 08:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The way I did them when I did the F&M bodies(pre-proto
type builds)was dial them up with out load them higher
than spec, then drop the car...jounce the front end...
take a measurement then if it was close when on
the ground... then take a 1/2 turn a out then jounce
again... if real close use less of a turn but jounce
the front every time... I never liked going up while
on the ground
Re: Torsion bar [Re: Moparmaniacc] #1148222
01/01/12 09:18 PM
01/01/12 09:18 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
You are better served when making ANY height adjustment to first loosen the LCA pivot shaft.
After making adjustments (loaded/unloaded doesn't really make a difference), bounce the heck out of the front end, and THEN retighten the pivot shaft.
If you skip this part of the procedure, the LCA bushing carries a load or "twist" at rest - which can lead to unnecessary wear on the bushing.
Down to just a blue car now.
Re: Torsion bar [Re: 68HemiB] #1148223
01/02/12 08:59 AM
01/02/12 08:59 AM
New York
rarefish Offline
rarefish  Offline
New York
Just remember that any height adjustment will effect your camber setting.
Re: Torsion bar [Re: rarefish] #1148224
01/02/12 12:45 PM
01/02/12 12:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In most cases that run a double A-arm it will affect
all 3 adjustments, camber, caster and toe in but
if you only move it a small amount it may not show up
Re: Torsion bar [Re: Moparmaniacc] #1148225
01/02/12 04:21 PM
01/02/12 04:21 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
Never raise it with the suspension fully loaded... I've learned that the painfull way! Even though I had cleaned the threads and put some anti seeze the threads sheared in the retainer and snap the ratchet out of my hands so fast that it teared my skin on my finger just by the friction of the smooth ratchet handle... Never again!
