Re: headers for brodix b1ba / a body
[Re: Hot 340]
#1147861
01/01/12 01:29 AM
01/01/12 01:29 AM
Posts: 526 NC
barracuda man
NC
Im sure some will chime in and tell you you cant run a stock port header on those heads. Ive done it for 15 years. I use a super comp header, cut off the flanges in between the tubes completely, and use a shortened plug socket with an angle ground on the hex side to clear the tube for the plugs.
I been grinding on the tti p-side header 4 hours and it fits great.started on the drivers side and what the F!!1.Wont work without some major fitment.think i'll call headman Tuesday.
[Re: Evil Spirit]
#1147863
01/01/12 01:41 AM
01/01/12 01:41 AM
Posts: 3,395 Pa
Hot 340
Pa
I think through the course of the B1-BA head the exhaust port has changed from typical small block port and pattern to a chevy style port and bolt pattern. It's possible the headers that work with early heads won't work with current ones.
Very possible on the bolt pattern. I think the ports are pretty much the same D port design though. Hemphill did mine back in 95 or 96. Dont know about the M/C version. OP, are yours the MC heads? Might be a difference.
[Re: Hot 340]
#1147864
01/01/12 01:45 AM
01/01/12 01:45 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
M/C's have undrilled pushrod holes and the exhaust bolt holes are also not drilled.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1147865
01/01/12 02:25 AM
01/01/12 02:25 AM
Posts: 3,395 Pa
Hot 340
Pa
Hemphill got mine in without the pushrod holes drilled. Angle milled slots in them for w2 setup. They are standard Ba's. All in what you want. The OP's might still be MC's he bought used.
