Sandblasters Not Working; Wet Media? How to Dry?
#1147322
12/31/11 11:19 AM
12/31/11 11:19 AM
Posts: 773 San Antonio, Tx
bulletpruf
San Antonio, Tx
Fellas -
I'm having problems with a few of my portable sandblasters. Two of them are the Sears model with the black plastic hopper and one is a Harbor Freight with a red metal hopper.
Bottom line is that I can't get any of them to blast for more than a few seconds before they stop. Media has been in each of them for several months in the garage, so I'm thinking that it's damp and that's clogging it up.
I've got an 80 gallon compressor with a water trap and regulator. Think I have the pressure set at 90 psi or so at the regulator. I could up the pressure but not sure if this will help.
I've used all types of media with no luck - right now I have one filled with sand (yes, I'm aware of the dangers of silicosis), one with medium grit coal slag/Black Beauty, and one set up with bead blasting media.
Thinking about putting the media in the oven and baking it at 400 degrees. That should dry it out, right?
Thanks for any input.
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Sandblasters Not Working; Wet Media? How to Dry?
[Re: dennismopar73]
#1147325
12/31/11 12:16 PM
12/31/11 12:16 PM
Posts: 1,992 midwest
68427vette
midwest
being in the midwest,, and aware of the "sweaty shop floors" yes,, mositure can build up on the inside,, and harden the media,,, you'll have to dig it out,, start over,,, and UP you psi from your 80 gallon tank,,, you can regulate it down at your "pot" of media,, i still have my small media pots,, but moved on...to a250 and 500 pots, with a john deer Ingersol 250 pull behind compressor and yes wear a good mask apperatus, as you stated! YOU DONT WANT TO BE ON o2. LATER IN LIFE,, JC could be your HOSE clogged, , that larger stuff, will clogg the exit hose,, and be care full that small pot doesnt tip over on you,, been there done that ,, and lots of f bombs!! ha ha
[Re: 68427vette]
#1147328
12/31/11 02:03 PM
12/31/11 02:03 PM
Challenger 1
Cincinnati, Ohio
""you can't sand blast without a air dryer that works.""
i dont have a dryer,, but i have a HUGE compressor,, works fine but i can regulate the back pressure, that forces the sand down and out..
jc
I have a huge diesel compressor that I have been using for years now, it still needs a air dryer. If you think you don't need a dryer, then you must not have done much blasting to have a water problem.
But like I said above, if your trying to get a sipon blaster to work...Good Luck! I've done a lot of blasting in the last 30 years, I did every inch if this tank and painted the whole thing and truck myself in 3 days. Completely painted in 3 colors in 3 days. Honest.
[Re: dennismopar73]
#1147329
12/31/11 03:31 PM
12/31/11 03:31 PM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Didn't know they could take 'silica' out of sand?
Yes, I stand corrected there. But the stuff I've been buying doesn't mention silica - maybe its quartz or something else !?!?
[Re: bulletpruf]
#1147331
12/31/11 04:00 PM
12/31/11 04:00 PM
Challenger 1
Cincinnati, Ohio
The black plastic one is a sipon feed blaster, it'll never work right or any better. Not sure about the HF one you mentioned if it a pressure pot or a sipon feed.
Got to use a pressure pot blaster to be able to get anything done.
Second You should run your air through at least 50-100' of metalic pipe before it get's to your air dryer so it can cool. Can't remove water from warm air. And you can't sand blast without a air dryer that works. As your finding out, don't wast your time with sipon feed blaster because they don't work well at all.
I've had the siphon feed blaster working well in the past, both with glass bead media and coal slag. That's what's bugging me.
I have a pressure pot blaster from Harbor Freight. It's filled with play sand, not blasting sand, so I'm pretty sure it's silica sand.
Scott
Gottcha, Get real blasting media which is dehydradeted and comes in plastic lined bags so it stays dry.
Play sand is just that, play sand. It's not dehydrated and is made for playing in, Is that what you want to do it with it? Play? I have blasted many bags of silca sand over the years, about 10 years ago they quit selling it here. Now they sell blasting slag which is low silca, it works just good as sand did and comes in at least 5 grades for different jobs. You buy blasting media from a place that sells bricks, because the use it to tuck point brick. Then there is plastic which is even better and won't warp panels. I did my gold 71. I blasted the underside and interior with slage and all the outside panels with plastic,urea plastic.
Getting back to your blaster, I hate to say it again, but. Invest in a pressure pot, you won't be sorry. I buy my media by the pallet, I have been on jobs 20 years ago where they had the blasting media delivered with a dump truck!
This blaster is the best unit to invest in, best value and performance. web page
[Re: rapom]
#1147333
12/31/11 10:13 PM
12/31/11 10:13 PM
68427vette
midwest
Sometimes you can put your hand over the nozzle and blow out the plug by back feeding the pressure. Use a glove. Also I use a dryer before the hose and a dryer at the blaster. Never had a moisture problem.
NOW thats NUTS!!! mine will take your skin off!!
no dryer, yet.....did this with my small hopper.
I have the 250 model pull behind,, and YES,, best investment i have bought, , It paid for itself in the first year!!! i am thinking about getting a dryer,, for soda!! no water problems,, i blead it out before filling the hopper,, my hopper has a water catch.
[Re: Challenger 1]
#1147334
01/01/12 11:52 AM
01/01/12 11:52 AM
bulletpruf
San Antonio, Tx
Scott
Got my siphon blaster to work yesterday. Swapped out the gun and it worked ok with some coal slag.
My pressure pot from Harbor Freight looks a lot like the one from Northern Tool that you recommend. Spent a little time on it yesterday, but not much luck. Will try again today with different media. If that won't work, I'll put the one from Northern Tool on my shopping list.
Scott
[Re: chrisf]
#1147336
01/01/12 02:58 PM
01/01/12 02:58 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i have a top load blast cabnet (decent size) i use black beauty in mine have found that if sets for a long time i need to stir it up before use i run a water sep off the compressor it helped a lot also most of the prob being is the media dont slide back down as easy/fast as ya think it would put a vibrator (air or ele.) on the side of your hopper will make a huge differance we have one on a pucker at work and night/day differance
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
