How do you run an auto trans engine on a stand? #114541
09/03/08 01:28 PM
09/03/08 01:28 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
The shop I'm considering sending my slant-6 to for a re-build (Picks Racing Engines, in Santa Ana) says they will run it on a stand when it's done. So, how does one start/run an engine that has an automatic transmission, when the tranny is not attached? That is, the starter gear is on the torque convertor, which I'm pretty sure probably can't be attached to the flex plate and used to start the engine (without the tranny also attached) - correct? Any suggestions would be appreciated, thanks.
Roger
Re: How do you run an auto trans engine on a stand? [Re: Fab64] #114542
09/03/08 01:32 PM
09/03/08 01:32 PM
NY usa
540challenger Offline
NY usa
Need a manual bellhousing to support the starter and a flywheel and you should be able to do it.
Re: How do you run an auto trans engine on a stand? [Re: 540challenger] #114543
09/03/08 01:52 PM
09/03/08 01:52 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Well, DUH - didn't think of that, thanks! I have a bellhousing from a 3-spd tranny out of a '62 Valiant that may work. Are slant-6 flywheels specific to that engine, or are there others that would work? This is a '67 225 cu. in.
Re: How do you run an auto trans engine on a stand? [Re: Fab64] #114544
09/03/08 02:08 PM
09/03/08 02:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Slant flywheels are grouped by bellhousing size and crank pilot diameter. If the motor has a '67 crank in it it will have the small register and you will need a '60-67 flywheel. '68 and up use the same size register as a small block.
Re: How do you run an auto trans engine on a stand? [Re: slantzilla] #114545
09/04/08 09:15 AM
09/04/08 09:15 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
you can also cut up a auto tranny case that is scrap and use it, but you will still need a flywheel. i have also used a midplate but getting the starter in the correct position can be a pita
