e-body hood spring r & r #1145413
12/27/11 10:09 PM
12/27/11 10:09 PM
central illinois
65dodgebob Offline OP
central illinois
anybody know the best way to remove hood springs from hinges while on car? without injury? thanks! car is 70 challenger with r/t hood.
Re: e-body hood spring r & r [Re: 65dodgebob] #1145414
12/27/11 10:53 PM
12/27/11 10:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Stuff washers in between the coils.
Re: e-body hood spring r & r [Re: Challenger 1] #1145415
12/27/11 11:22 PM
12/27/11 11:22 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Support the hood first!
Then hook the front loop with a fan belt pulling toward the front of the car and unhook it.
Last, let the spring pull back.
It's easier & less likely to cause damage if you have a helper to catch it after you release the tension.
It's not as difficult as it might sound
Re: e-body hood spring r & r [Re: RestoRick] #1145416
12/28/11 09:22 AM
12/28/11 09:22 AM
London, England
Gavin Offline
Gavin  Offline
London, England
It is pretty easy to do it like this, there is no major risk of springs releasing suddenly and causing carnage, you'll be surprised
