Ebody door locks #1145339
12/27/11 07:48 PM
12/27/11 07:48 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Hi. Can someone explain the workings of a 70 Cuda door lock setup. I just installed them and pass side when you lock from inside you can,t open from the outside (which is great) but ican still open from inside handle. The Drivers side i can open from inside and outside when internal lock is set. I have all the rods in the right way. I did notice that pass side has a tab on the mechanism where the drivers side has not. The key does work on both doors to lock and unlock Thanks in advance
Re: Ebody door locks [Re: 300_dup5] #1145340
12/27/11 07:55 PM
12/27/11 07:55 PM
I'd say that the dr side needs a lock cyl with the tab like it's counterpart on the pass side so they'll function the same
Re: Ebody door locks [Re: RapidRobert] #1145341
12/27/11 08:12 PM
12/27/11 08:12 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
When you set the internal lock levers, and get out and close door that should lock it right or do you still need key?
Re: Ebody door locks [Re: 300_dup5] #1145342
12/27/11 08:31 PM
12/27/11 08:31 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
real Mopar guys never lock their doors or use gasket sealant . i believe you have to hold the handle out with the lock button pushed to lock? E-bodys don't have a handle with the push button right?
Re: Ebody door locks [Re: mikemee1331] #1145343
12/27/11 09:05 PM
12/27/11 09:05 PM
BDW Offline
BDW  Offline
Not sure of your question, but 70's have a special "feature" that you can't lock the door and then close it, and it remain locked.
I found this annoying, especially for the passenger side. You have to stay in car and reach over and lock, or walk around and lock with key.
I modified mine, pic shows the area.
Re: Ebody door locks [Re: BDW] #1145344
12/27/11 09:27 PM
12/27/11 09:27 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
ThanKs for all your posts, I,ll just use the key. 70 is one of it,s own that,s for sure
