318 rering or not???????????? #1142430
12/23/11 01:47 PM
12/23/11 01:47 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
I'm currently building a plow truck. have a 85 318 tore down going to bearing it, cam and chain and put some rebuilt 360 heads on it.Question being would it be worth it to rering with lets say total seal rings ? motor had 90,000 on it when pulled.thanks,Nate
Trucks/cars there all MOPARS 98 w2500 cummins24v5spd 85 w350 crew/short360 78 w150 shortfact.440 with upgrades 87 w150 soon to be new snowfighter 75 duster.... project since1999... never to be completed
Re: 318 rering or not???????????? [Re: Duster75] #1142431
12/23/11 04:16 PM
12/23/11 04:16 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Did you leave the pistons in? How are the bores? Taper? Finish? How's the piston to cyl clearance?
Re: 318 rering or not???????????? [Re: radar] #1142432
12/23/11 04:34 PM
12/23/11 04:34 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
pistons in yet.... don't have a bore scope,inside mic. to check.Finish is smooth with no cross hatch I checked in as far as my caliper would reach and it was 3.9 I want too say I would say that would be too close to top though.nate
Re: 318 rering or not???????????? [Re: Duster75] #1142433
12/23/11 05:20 PM
12/23/11 05:20 PM
Buy a moly ring set. Carefully cut the ridge. break it in hard to seat the moly rings on the smooth finish, change oil/filter & put it in use. Read "breakin secrets" at www.mototuneusa.com
Re: 318 rering or not???????????? [Re: RapidRobert] #1142434
12/23/11 06:55 PM
12/23/11 06:55 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
carefully cut ridge????? I assume you mean hone? Interesting article thanks, Nate
Re: 318 rering or not???????????? [Re: Duster75] #1142435
12/23/11 07:48 PM
12/23/11 07:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is the block on a stand or in the truck... I would
change rings... hit it with a ball hone/deglazer,
gap the rings and install
Re: 318 rering or not???????????? [Re: MR_P_BODY] #1142436
12/23/11 08:14 PM
12/23/11 08:14 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
on the stand..... having a hard time finding rings for some reason
Re: 318 rering or not???????????? [Re: Duster75] #1142437
12/23/11 08:21 PM
12/23/11 08:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
you may loose low end torque with the 360 hesds. They have a larger combustion chamber..
I am truckless..
Re: 318 rering or not???????????? [Re: Duster75] #1142438
12/23/11 08:29 PM
12/23/11 08:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you check Summit
Re: 318 rering or not???????????? [Re: MR_P_BODY] #1142439
12/23/11 08:40 PM
12/23/11 08:40 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Re: 318 rering or not???????????? [Re: Duster75] #1142440
12/23/11 08:52 PM
12/23/11 08:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
No - cutting out the ridge requires a special ridge cutter tool.
Re: 318 rering or not???????????? [Re: MoparforLife] #1142441
12/23/11 09:02 PM
12/23/11 09:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... if there is a ridge you need to rent a ridge
reamer
Re: 318 rering or not???????????? [Re: MoparforLife] #1142442
12/23/11 09:11 PM
12/23/11 09:11 PM
With it on the stand yes get a ball hone of the right grit for moly rings (may be #320). Moly rings are much better than cast iron but sometimes a bore w a great amt of taper and or out of round will seal better with cast iron. Didn't realize it was out of the truck/stripped to bare block. Sure you dont want to go a slight bit further & bore it? That'd give you a 318 that'd last (nearly) forever & only cost a slight bit more esp since you're already apart
Re: 318 rering or not???????????? [Re: RapidRobert] #1142443
12/23/11 09:25 PM
12/23/11 09:25 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
A worn bore and a backyard hone'n're-ring job, I would be using plain old cast rings, not moly. Moly coated rings seal better and break in quicker but they are not as forgiving on a worn bore as cast rings. Hastings cast rings are a good choice for these types of builds IMO.
Re: 318 rering or not???????????? [Re: DaytonaTurbo] #1142444
12/23/11 09:47 PM
12/23/11 09:47 PM
scratchnfotraction Offline
100%
most 85 318 with roller cam #302 heads had the moly rings stock.
they do well on bore wear and tappor,MY 300,00 mile 88 is still in specs for a rering with used pistons.
i will slap a set of stock cast rings in wafter a dingle ball hone job to clean them up some.
if its in specs its in specs for a re-ring
i may not get another 300,00 but another 150,000 will work for the price.
Re: 318 rering or not???????????? [Re: scratchnfotraction] #1142445
12/23/11 10:00 PM
12/23/11 10:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
100%
Yeah with the nickle content that the blocks have had
for a number of years it isnt the block that wears
Re: 318 rering or not???????????? [Re: MR_P_BODY] #1142446
12/23/11 11:01 PM
12/23/11 11:01 PM
Manitoba, Canada
Manitoba, Canada
100%
Plus the blocks that came factory with the moly rings wear the bores a lot less than the regular cast rings did. However that's not to say than an engine that came with moly rings from the factory is guaranteed to still have bores that would meet the requirements for a new set of moly rings.
Re: 318 rering or not???????????? [Re: DaytonaTurbo] #1142447
12/24/11 10:18 AM
12/24/11 10:18 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
hone and put new rings in...
when I did my 318, the local carquest charged $8/bore to toss it on their machine and hone it.
2017 Grand Cherokee Overland
Re: 318 rering or not???????????? [Re: patrick] #1142448
12/24/11 12:22 PM
12/24/11 12:22 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
Well,thanks for replies.I don't want to bore it cause I know where that will lead.....if your going that far you might as well line bore and turn crank etc. its just a 318 for a plow truck using up some parts to make a better than junkyard engine.Mancini has rings they didn't have cam I wanted so Jegs got my business, but they didn't have rings...so northen will be sending out rings. Guess I will go with cast. Will break in be the same with cast? Wish I had a local machine shop that would hone for me. Newbe to the hone ridge cuttting world. Thanks,Nate
Re: 318 rering or not???????????? [Re: scratchnfotraction] #1142449
12/24/11 12:28 PM
12/24/11 12:28 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
100%
No roller cam in this 85 block
