Eastwood Rust Encapsulator VS POR 15. #1142285
12/23/11 09:23 AM
12/23/11 09:23 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
For the 1st time I've tried the Eastwood product. For years I've used POR 15. POR 15 spreads very well with a sponge brush. The Eastwood stuff spreads like watered down paint. I had to use more coats. Anyone else notice this? Seems like the Eastwood product would be best sprayed on.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Eastwood Rust Encapsulator VS POR 15. [Re: TimS] #1142286
12/23/11 12:10 PM
12/23/11 12:10 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello, Yes, I noticed the same thing. I used the Eastwood encapsulator first and didn't care for it at all. I went over everything a second time using POR15. I could tell which was better due to the fact that the Eastwood stuff would come off my hands fairly easy, the POR15, different story! Jeff
Re: Eastwood Rust Encapsulator VS POR 15. [Re: 1969RR] #1142287
12/23/11 12:54 PM
12/23/11 12:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I haven't used either but do want to make a point ...
rust is porous, therefore a "thinner" produxt would penetrate the rust whereas a thicker product will only cover it. Sometimes better results take a little more effort!
Re: Eastwood Rust Encapsulator VS POR 15. [Re: TimS] #1142288
12/23/11 03:57 PM
12/23/11 03:57 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I believe Eastwood is kind of like pre-thinned POR-15 to make it sprayable.
Just a theory...
Rust Bullet is thinner than POR-15 also.
I've tried thinning down POR-15 to spray it and then they seemed about equal.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: Commando1] #1142289
12/23/11 07:04 PM
12/23/11 07:04 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Just a theory...
Very good point. That would be my take. POR15 definately penetrates, no question there. It's an ease of application question but after trying both, POR 15 is much more user friendly when applying with a sponge brush, hands down. The Eastwood brand appears to be a spray gunners dream. Too thin and runny to sponge brush however.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: TimS] #1142290
12/23/11 08:08 PM
12/23/11 08:08 PM
midwest
68427vette Offline
68427vette  Offline
midwest
if you paint over the por15,, you must scuff/ cut it with at least 320 paper,, to give the next coat of paint something to bite onto,, otherwise your paint will chip, fall off,, jc
Re: Eastwood Rust Encapsulator VS POR 15. [Re: 68427vette] #1142291
12/23/11 09:08 PM
12/23/11 09:08 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The rocker panels on my pickup are starting to blister on the bottom. How effective do you think it would be to remove the small body plugs on the back side and pour/squirt Eastwood Rust Encapsulator inside and rock the truck back and forth???
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Eastwood Rust Encapsulator VS POR 15. [Re: 68427vette] #1142292
12/23/11 09:26 PM
12/23/11 09:26 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
Has anybody used por-15 then their ty-coat primer then paint it. They claim you can put the ty-coat on and it can be painted over with no adhesion problems. Has anybody tried this.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: 340swing] #1142293
12/23/11 10:42 PM
12/23/11 10:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've done (sprayed) a complete body (Cuda) in the clear POR-15, over all the lead and body filler, then coated with Dupont primer-surfacer, then primed/paint with no issues....paint has been on the car for 10+yrs,....and I didn't sand the POR-15 prior to sealing
Re: Eastwood Rust Encapsulator VS POR 15. [Re: GO_Fish] #1142294
12/23/11 11:58 PM
12/23/11 11:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well you could do that if you're a sucker for punishment OR you could just buy their Internal Frame Coating.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: Stanton] #1142295
12/24/11 12:11 AM
12/24/11 12:11 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
That's a good tip! I'll check it out.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: GO_Fish] #1142296
12/25/11 12:42 AM
12/25/11 12:42 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
We tried something similar on the quarters around the wheelwell. There wasn't much through rust and that was cut out and patched with steel. The POR15 was shot in 'till it was running out the drain holes. Still rusted (about 10 years including some winter use). Really was the wrong approach. If the surface can't be properly prepped a paint type finish coating will not work. Maybe Corroless if you want to import it, but even there its not made to be applied blind. Much better to use a product like Waxoyl (usually available from places that deal with Brit cars). LPV3 is/was a similar product if you don't have much to do as its available in spray cans.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: Mattax] #1142297
12/25/11 01:01 AM
12/25/11 01:01 AM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
i have ried both the Eastwood product and POR, both do basically what they say they will. I recently tried Chassis Black from Monstaliner on the bottom and inside my Cuda, that stuff rocks! I spreayed it on; it goes on thin but sticks like nothing I have ever seen. I painted my 52 Dodge B2B with it as well. Didnt prep either and it really adheres to whatever you put it on. In fact I had painted one component of the truck that I needed to weld on later, so I tried to bead blast it off, it was very difficult to get off. I highly recommend it and will use it again.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: Eastwood Rust Encapsulator VS POR 15. [Re: Mattax] #1142298
12/25/11 01:11 AM
12/25/11 01:11 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
I sprayed the underside of the charger using their rust encapsulator then did it with their extreme chassis black... here are the results.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: BEINGmeISaCRIME] #1142299
12/25/11 01:12 AM
12/25/11 01:12 AM
Kansas
Kansas
extreme black
Re: Eastwood Rust Encapsulator VS POR 15. [Re: TimS] #1142300
12/30/11 10:07 PM
12/30/11 10:07 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I think the Rust Encapsulator sold now is thinner than it used to be. Zero Rust is a very similar product. I like it better. Alkyd enamels and moisture cured urethanes are worlds apart but the former is easer it use and seem to garner less complaints than the latter.
Re: Eastwood Rust Encapsulator VS POR 15. *DELETED* *DELETED* [Re: TimS] #1142301
12/30/11 10:18 PM
12/30/11 10:18 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Duplicate post deleted by 70Duster440
Re: Eastwood Rust Encapsulator VS POR 15. [Re: 70Duster440] #1142302
12/31/11 04:32 AM
12/31/11 04:32 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
HOW does some of this stuff work on edges of body-panels where they are folded-over then welded together ? ... like on the front leading edge of a hood.
Re: Eastwood Rust Encapsulator VS POR 15. [Re: dOrk !] #1142303
12/31/11 02:47 PM
12/31/11 02:47 PM
USA
ramairthree Offline
ramairthree  Offline
USA
I used the spray can rust encapsulator on the inside floor of the RR.
It looked great,
but wanted to give it something to last.
