Need a little help with an Ultra Bell Install, easy one #1141990
12/22/11 06:34 PM
12/22/11 06:34 PM
MN
mkvien Offline OP
mkvien  Offline OP
MN
I got all done cutting and installing my Ultra Bell on a 727 and realized that I left this part out, it was originally installed on the top two bolts of the pump housing, do I need to tear it apart and install this? What does it do?
Thanks guys...
Re: Need a little help with an Ultra Bell Install, easy one [Re: mkvien] #1141991
12/22/11 06:48 PM
12/22/11 06:48 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
that is the cover for the vent. put it on. merryxmas. seeya.
Re: Need a little help with an Ultra Bell Install, easy one [Re: mkvien] #1141992
12/22/11 06:49 PM
12/22/11 06:49 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
cover for vent in oil pump housing, most plug it and vent from rear. i tapped mine for 1/8 pipe plug
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Need a little help with an Ultra Bell Install, easy one [Re: 440lebaron] #1141993
12/22/11 09:19 PM
12/22/11 09:19 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
hello,
gary
Re: Need a little help with an Ultra Bell Install, easy one [Re: B G Racing] #1141994
12/28/11 12:22 PM
12/28/11 12:22 PM
MN
mkvien Offline OP
mkvien  Offline OP
MN
Back in the shop after spending some family time... The new bell covers that hole completely, or at least the direct line of sight. There is an air gap back there so it can vent. Installing that cover will act as a shim, I believe, causing misalignment of the transmission, any further comments?
Re: Need a little help with an Ultra Bell Install, easy one [Re: mkvien] #1141995
12/28/11 07:23 PM
12/28/11 07:23 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
pull the support, diss the pump, tap the vent hole- make sure the pipe plug is flush outside & inside. put the vent on top of the tail shaft housing in the middle, towards the front of the hsg. i put in a 1/8 pipe 90 & ran a hose up to the firewall & put the vent there. never had a problem. seeya.
