904 tailshaft bolts #114175
09/02/08 06:42 PM
09/02/08 06:42 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Are the tail shaft bolts on a 904 "Wet"?? I have a mysterious ATF leak after replacing my tailshaft with a new gasket and wonder if the slow leak is creeping out of the bolt threads. Easy fix if it is.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 904 tailshaft bolts [Re: CJK440] #114176
09/02/08 07:09 PM
09/02/08 07:09 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I dont have a case in front of me I know some of the bolts are wet not sure if all 6 are or not
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 904 tailshaft bolts [Re: dusturbd340W5] #114177
09/02/08 07:29 PM
09/02/08 07:29 PM
dry EDIT I do not know.
Re: 904 tailshaft bolts [Re: RapidRobert] #114178
09/16/08 10:52 AM
09/16/08 10:52 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I pulled the tail and "think" the leak was coming from the low band apply lever shaft. It has an O-ring and think that was it.
But at least all the lower tail bolts go right into the main case and are wet so I'll make sure I put a little goo on the threads when I put it back on.
This way all the bases will be covered.
Re: 904 tailshaft bolts [Re: CJK440] #114179
09/16/08 11:01 AM
09/16/08 11:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
chris i usually slide the reverse rod in , with the oring intstaklled , put a band of rtv on the shaft ahead of the o ring and slide it home , let the RTV set .
Re: 904 tailshaft bolts [Re: JohnRR] #114180
09/16/08 01:05 PM
09/16/08 01:05 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I pushed it in, cleaned the recess with brake cleaner and filled it with RTV and skimmed if off with a spackle knife.
That coupled with some gasket tack on the rear gasket and some non hardening sealer on the bolts should do the trick just nicely.
