904 tailshaft bolts
#114175
09/02/08 06:42 PM
09/02/08 06:42 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Are the tail shaft bolts on a 904 "Wet"?? I have a mysterious ATF leak after replacing my tailshaft with a new gasket and wonder if the slow leak is creeping out of the bolt threads. Easy fix if it is.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 904 tailshaft bolts
[Re: CJK440]
#114176
09/02/08 07:09 PM
09/02/08 07:09 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I dont have a case in front of me I know some of the bolts are wet not sure if all 6 are or not
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#114177
09/02/08 07:29 PM
09/02/08 07:29 PM
RapidRobert
dry EDIT I do not know.
[Re: RapidRobert]
#114178
09/16/08 10:52 AM
09/16/08 10:52 AM
CJK440
Ansonia, CT
I pulled the tail and "think" the leak was coming from the low band apply lever shaft. It has an O-ring and think that was it.
But at least all the lower tail bolts go right into the main case and are wet so I'll make sure I put a little goo on the threads when I put it back on.
This way all the bases will be covered.
[Re: JohnRR]
#114180
09/16/08 01:05 PM
09/16/08 01:05 PM
CJK440
Ansonia, CT
I pushed it in, cleaned the recess with brake cleaner and filled it with RTV and skimmed if off with a spackle knife. That coupled with some gasket tack on the rear gasket and some non hardening sealer on the bolts should do the trick just nicely.
