Hans system #1141745
12/22/11 01:42 PM
12/22/11 01:42 PM
SD USA
neonic Offline OP
neonic  Offline OP
SD USA
Does anyone know if a neck collar is still required when you use a Hans type system.
Re: Hans system [Re: neonic] #1141746
12/22/11 03:13 PM
12/22/11 03:13 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
My buddys I have worn a few times there really wasn't a way you could wear one even if you wanted too. I would think not though, might ought to call whoever you got it from.
One day I will have something cool here.
Re: Hans system [Re: neonic] #1141747
12/22/11 04:06 PM
12/22/11 04:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
NO
Re: Hans system [Re: Challenger 1] #1141748
12/22/11 04:12 PM
12/22/11 04:12 PM
organ
maximum entropy Offline
organ
i think a hans device is a good idea for any racer at any level. hit a wall at 50mph lately? think you can control what your head is gonna do? heh.
Re: Hans system [Re: maximum entropy] #1141749
12/22/11 04:22 PM
12/22/11 04:22 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yup I hit the wall at 240MPH and it almost did rip my head off, almost. Didn't have a Hans on then, I wear one now.
Re: Hans system [Re: Challenger 1] #1141750
12/22/11 04:55 PM
12/22/11 04:55 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
If you are faster than 7.49 or open bodied car in the 1/4, then a Hans device is required with a helmet skirt or or head sock. If running T/D or Top Sportsman, then it is required to have the Hans with the skirt or head sock. I can't see how a neck collar would even work with a Hans device.
Re: Hans system [Re: maximum entropy] #1141751
12/22/11 05:00 PM
12/22/11 05:00 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I was driving a 3/4 ton van on the street pulling away from a traffic light, so about 10-15 mph. Got hit on the LR tire spun me 180 degrees. Other car 35-40 mph ran red light. 14 months later I had an artifical disc & titanium plate permenantly installed in my neck just below the brain stem.
I bought a neck collar to use & the car was only a high 11 to low 12 second bracket car. Gotta protect head & neck as it dosen't take much to cause very serious life threatening injuries.
Re: Hans system [Re: aquamist60] #1141752
12/23/11 01:37 PM
12/23/11 01:37 PM
SD USA
neonic Offline OP
neonic  Offline OP
SD USA
OK, I was looking at the Hybrid pro. I seen Force and Capps both have neck collars on with these systems. I see other drivers with different systems without neck collars.
Re: Hans system [Re: neonic] #1141753
12/25/11 04:18 AM
12/25/11 04:18 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
The Hybrid Pro is the best there is . I tried them all .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Hans system [Re: go green] #1141754
12/25/11 10:34 AM
12/25/11 10:34 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
I have a Hans with the quick release tethers, I would not get in a racecar without it. No way a collar will work with it as stated previously.
Mike Gray
Merry Christmas
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
