727 stator support modifications ? #1141715
12/22/11 12:29 PM
12/22/11 12:29 PM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
Hi anyone
I got some lock-up stator reaction shaft supports laying around that I would like to convert to non-lock up.
Did anyone ever do that? Can I just remove the 3rd checkball and that’s it? If yes, how do I do it the best way, any tricks?
Same for the 74-77 supports, can I drill that little lube hole to convert it to a 71-74 type?
Re: 727 stator support modifications ? [Re: 6o4o] #1141716
12/29/11 01:40 PM
12/29/11 01:40 PM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
nobody?
Re: 727 stator support modifications ? [Re: 6o4o] #1141717
01/02/12 06:56 PM
01/02/12 06:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 727 stator support modifications ? [Re: 6o4o] #1141718
01/02/12 08:54 PM
01/02/12 08:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't have the two side-by-side to compare but I do know that removing the third ball will merely dump rear clutch apply pressure into the converter.
The '74-'77 can have the lube hole added, takes an extension drill....I use a #40.
Re: 727 stator support modifications ? [Re: 6o4o] #1141719
01/02/12 10:44 PM
01/02/12 10:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hi anyone
On my 518 trans that I changed to a regular 727 with
OD, I had to change the input shaft(without the hole)
and the pump housing due to the ports and balls
Re: 727 stator support modifications ? [Re: MR_P_BODY] #1141720
01/03/12 12:43 AM
01/03/12 12:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hi anyone
Good point , you can't just modify the stator support , you must also change the input shaft.
Re: 727 stator support modifications ? [Re: JohnRR] #1141721
01/03/12 08:23 AM
01/03/12 08:23 AM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
I know about the input shaft, I got non lock up >78 input shafts but missing the non lock up reaction shaft supports (were scored too bad, I did throw them away!)
Here a picture.. I just wanted to be sure it's only the ball and not some inside passage that I might not have think about...
On the 74-77 thanks, then I will just drill that hole! I got a few 74-77 supports but none 71-73...
Re: 727 stator support modifications ? [Re: 6o4o] #1141722
01/03/12 12:38 PM
01/03/12 12:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I talked to John Cope(Cope Racing Trans) I believe
that all he said was the ball and the input shaft
was needed
