Re: 3.58" crank
[Re: Crizila]
#1141602
12/22/11 12:44 PM
12/22/11 12:44 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
What's the intended use? For a 90% street car, a cast (MP/SCAT) crank will be fine. But if I were going to race one, I'd have it INTERNALLY balanced vs. external. Then you might as well take the money you're going to spend balancing and get the forged piece to begin with.
Re: 3.58" crank
[Re: 416challenger]
#1141606
12/23/11 12:45 AM
12/23/11 12:45 AM
Posts: 799 north west LA
W2DODGE
north west LA
Nothing wrong with a stock crank. I made upwards of a thousand 10.60 passes in my 3,000 lb dart before it went into my buddies car for several seasons he spun a rod bearing not the cranks fault. I have also run cast 318 cranks in the same car in the 11.10 10.90 range.
Re: 3.58" crank
[Re: Rapid340]
#1141611
12/23/11 01:27 PM
12/23/11 01:27 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
Density is increased by the forging process itself, even the cast steel cranks are lighter. Rotating weight can be a great place to go on a diet and often costs less than free.
Is that correct? I do not think the density is much different if cast or forged, however, I am not so sure the socalled Cast steel cranks are really that!! Steel is difficult to cast, but iron is simple, and some people say their nodular cast iron cranks are cast steel!! 4% carbon make them all lighter than steel by appx 5%. If the Scat 4" stroker cranks really was cast steel (I think I read so) I would buy them right away at 300$, or any comments???
Re: 3.58" crank
[Re: Oyvind Mopar]
#1141612
12/23/11 02:18 PM
12/23/11 02:18 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
Quote: Quote:
Quote: --------------------------------------------------------------------------------
I would think that forging anything could increase its density but if that is not the case I stand corrected. I went to the scat website and they refer to the cast cranks as "CAST PROCOMP" but dont call them cast steel anywhere I can see. I think they have been advertised as cast steel ( by resellers? ) in the past and "cast 9000 series". Scat shows the weight of the SB mopar cast crank as four pounds less than the their 4340 forged crank (56lbs vs. 60lbs). Maybe these things being true cast steel is a myth.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 3.58" crank
[Re: Oyvind Mopar]
#1141614
12/24/11 10:15 AM
12/24/11 10:15 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
no it's not unless the cast billet the forged crank is shaped from has serious voids....
steel casting isn't too tough, one of our customers does it all the time....
if a "cast steel" crank of the same dimensions is significantly lighter than a forged crank with the same volume of material, it's actually nodular (ductile) iron...where steel is the continuous phase, and there's spherical nodules of carbon dispersed throughout.
Re: 3.58" crank
[Re: W2DODGE]
#1141615
01/13/12 02:36 PM
01/13/12 02:36 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I just got done skinning some big old swamp rabbits they aint got them on the left coast or road kill gumbo.
LA as in Cajun country? Or LA as in Hollywood?
I know a guy from Louisiana that said he had some quick 318s. Coincidence?
Just saw the reply, How's retirement treating you Sherred?!
It's me, your favorite LT who was building the big block Dakota, was your Flt commander back in 05-06 time frame
(Ok, I assumed a little, might not have been your "favorite" Lt!)
**Photobucket sucks**
Re: 3.58" crank
[Re: patrick]
#1141616
01/13/12 02:56 PM
01/13/12 02:56 PM
Posts: 2,128 sweden
sshemi
sweden
A forged thing is heavier then a cast thing.
