3.58" crank #1141597
12/22/11 01:44 AM
12/22/11 01:44 AM
New Braunfels, TX
416challenger Online content OP
416challenger  Online Content OP
New Braunfels, TX
I guy I know want me to put together a 360 for him. He has everthing, but the crank. I tried to get him to buy a forged crank, but he does not have the money. What cast crank do you guys recommend? What is the difference between the Eagle and Mopar besides about $150. Does Scat or K1 make cast 3.58" cranks?
Re: 3.58" crank [Re: 416challenger] #1141598
12/22/11 01:53 AM
12/22/11 01:53 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No worries about the cast crank...........I know someone personally going low 9`s w a smallblock n/a..........
Re: 3.58" crank [Re: 416challenger] #1141599
12/22/11 02:05 AM
12/22/11 02:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The Mopar crank is a Scat crank (they make it for Mopar)
Re: 3.58" crank [Re: MR_P_BODY] #1141600
12/22/11 08:48 AM
12/22/11 08:48 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Does he have a factory crank? They're pretty tough from what i've seen. Otherwise, i'd run a scat/mopar crank.
Re: 3.58" crank [Re: 416challenger] #1141601
12/22/11 11:02 AM
12/22/11 11:02 AM
Az
Crizila Offline
Crizila  Offline
Az
You have a PM.
Fastest 300
Re: 3.58" crank [Re: Crizila] #1141602
12/22/11 12:44 PM
12/22/11 12:44 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
What's the intended use? For a 90% street car, a cast (MP/SCAT) crank will be fine. But if I were going to race one, I'd have it INTERNALLY balanced vs. external. Then you might as well take the money you're going to spend balancing and get the forged piece to begin with.
Re: 3.58" crank [Re: cudadoug] #1141603
12/22/11 05:08 PM
12/22/11 05:08 PM
New Braunfels, TX
New Braunfels, TX
I agree with going with the forged crank, but he says he does not have the money. The car will only be raced, no street driving. He says he plans to run points, but the last couple years only comes out about 3 times a year.
A few years ago I ran a 360 in my car that was put together with parts I had laying around. It was a factory crank that was externally balanced with ported RPM heads and a 242 duration cam. It ran extremely well for what is was and I had over 350 passes without any problems. Since it was built with left over parts it wasn't a big deal if it blew up.
The parts he is planning on using are similar too what I had, he just doesn't have a crank. I know inexpensive and quality don't generally go together, but I need something that will stay together.
Re: 3.58" crank [Re: 416challenger] #1141604
12/22/11 05:18 PM
12/22/11 05:18 PM
Delray beach, Florida
P
Performance Only Offline
P
there's really nothing wrong with the factory cast crank. they're pretty tough for being cast. if you decide to go that route i'll take a look to see if i have a core in one of the crank racks. i would rather run a factory cast than the eagle cast. the Scat crank isn't that expensive and is a better piece altogether. those are cast steel, instead of iron.
machine shop owner and engine builder
Re: 3.58" crank [Re: Performance Only] #1141605
12/22/11 05:52 PM
12/22/11 05:52 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The car should perform slightly better with a cast crank because it has less inertia will reduce front end weight. The OEM or SCAT/MOPAR cranks will withstand some severe abuse.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 3.58" crank [Re: 416challenger] #1141606
12/23/11 12:45 AM
12/23/11 12:45 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
Nothing wrong with a stock crank. I made upwards of a thousand 10.60 passes in my 3,000 lb dart before it went into my buddies car for several seasons he spun a rod bearing not the cranks fault. I have also run cast 318 cranks in the same car in the 11.10 10.90 range.
Re: 3.58" crank [Re: W2DODGE] #1141607
12/23/11 01:49 AM
12/23/11 01:49 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
LA as in Cajun country? Or LA as in Hollywood?
I know a guy from Louisiana that said he had some quick 318s. Coincidence?
**Photobucket sucks**
Re: 3.58" crank [Re: 416challenger] #1141608
12/23/11 04:31 AM
12/23/11 04:31 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
The factory cranks with a 'CFD' cast into them are apparently a little better than the 'AAWJ' garden veriety ones, although they all seem to hold up pretty well.
Re: 3.58" crank [Re: Rapid340] #1141609
12/23/11 08:16 AM
12/23/11 08:16 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
not if it's cast steel...density is the same...a nodular (ductile) iron crank will be about 10% lighter, so you're saving about 4 lbs....which won't make much difference...
for that stroke, unless he's planning on making like 700HP, stock will be plenty durable.
2017 Grand Cherokee Overland
Re: 3.58" crank [Re: patrick] #1141610
12/23/11 01:01 PM
12/23/11 01:01 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Density is increased by the forging process itself, even the cast steel cranks are lighter. Rotating weight can be a great place to go on a diet and often costs less than free.
Disclaimer: I would be looking at a forged piece at power levels much lower than 700.
Re: 3.58" crank [Re: Rapid340] #1141611
12/23/11 01:27 PM
12/23/11 01:27 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Is that correct? I do not think the density is much different if cast or forged, however, I am not so sure the socalled Cast steel cranks are really that!! Steel is difficult to cast, but iron is simple, and some people say their nodular cast iron cranks are cast steel!! 4% carbon make them all lighter than steel by appx 5%.
If the Scat 4" stroker cranks really was cast steel (I think I read so) I would buy them right away at 300$, or any comments???
Re: 3.58" crank [Re: Oyvind Mopar] #1141612
12/23/11 02:18 PM
12/23/11 02:18 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I would think that forging anything could increase its density but if that is not the case I stand corrected. I went to the scat website and they refer to the cast cranks as "CAST PROCOMP" but dont call them cast steel anywhere I can see. I think they have been advertised as cast steel ( by resellers? ) in the past and "cast 9000 series". Scat shows the weight of the SB mopar cast crank as four pounds less than the their 4340 forged crank (56lbs vs. 60lbs). Maybe these things being true cast steel is a myth.
Re: 3.58" crank [Re: 70Cuda383] #1141613
12/23/11 10:51 PM
12/23/11 10:51 PM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
I just got done skinning some big old swamp rabbits they aint got them on the left coast or road kill gumbo.
Re: 3.58" crank [Re: Oyvind Mopar] #1141614
12/24/11 10:15 AM
12/24/11 10:15 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
no it's not unless the cast billet the forged crank is shaped from has serious voids....
steel casting isn't too tough, one of our customers does it all the time....
if a "cast steel" crank of the same dimensions is significantly lighter than a forged crank with the same volume of material, it's actually nodular (ductile) iron...where steel is the continuous phase, and there's spherical nodules of carbon dispersed throughout.
Re: 3.58" crank [Re: W2DODGE] #1141615
01/13/12 02:36 PM
01/13/12 02:36 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Just saw the reply, How's retirement treating you Sherred?!
It's me, your favorite LT who was building the big block Dakota, was your Flt commander back in 05-06 time frame
(Ok, I assumed a little, might not have been your "favorite" Lt!)
Re: 3.58" crank [Re: patrick] #1141616
01/13/12 02:56 PM
01/13/12 02:56 PM
sweden
sshemi Offline
sshemi  Offline
sweden
A forged thing is heavier then a cast thing.
