Crank is broken
#1140903
12/21/11 04:21 PM
12/21/11 04:21 PM
Posts: 339 California
moparbroz
California
On a cherry picker and down the 440 went. Landed on the crankshaft pully and broke the end of the crankshaft clean off. I am by far not a motor guru and I know that I need a new balanced crank and to balance I need to get a machine shop a piston and rod. Should I attempt this myself or just drop off my motor? I have a highly recommended motor guru who I can have do the job.
Hebrews 11:1
Re: Crank is broken
[Re: moparbroz]
#1140904
12/21/11 04:29 PM
12/21/11 04:29 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
UMMM,, WOW, I would definatly have that block checked for any cracks from the impact. Every main got a shock when that ol girl hit, and I mean a side shock, stressing the bolts, and the webbing of the block where a load like that was NEVER designed to hit it. Crazy how that broke. Glad you arent hurt, that could have gotten really nasty. Kasey
Re: Crank is broken
[Re: BigBlockMopar]
#1140908
12/21/11 09:55 PM
12/21/11 09:55 PM
Posts: 1,443 Maryland
Dads426
Maryland
I got a cherry cast crank that you can have if you want to pay shipping from the east coast. Should be able to find one out there for less than shipping though.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
Re: Crank is broken
[Re: Kern Dog]
#1140912
12/22/11 03:42 AM
12/22/11 03:42 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
If you look at the squareness of the counterweights you can tell it's cast, plus, a forged would likely not have broken like that. Regardless, I doubt it hurt the block, but I would replace at least that one upper main bearing on #1. If the motor is stock (factory rods and pistons) another stock cast crank that has never been molested should be close enough in balance. If it bothers you, definitely have the balance checked. Take the harmonic balancer and let them know the rear is also externally balanced. If you have a stick trans, take the flywheel, otherwise you're almost stuck buying a B&M external flexplate.
Re: Crank is broken
[Re: Dads426]
#1140913
12/22/11 11:26 AM
12/22/11 11:26 AM
moparbroz
California
John - Awesome offer! I really appreciate it. I will take you up on it if that is ok. My zip is 92867. Orange, CA. Thanks!
Hebrews 11:1
Re: Crank is broken
[Re: Kern Dog]
#1140914
12/22/11 11:28 AM
12/22/11 11:28 AM
moparbroz
California
Sorry Frankenduster. I didn't disapear, just had a bunch of stuff to do.
Hebrews 11:1
Re: Crank is broken
[Re: dodgeboy11]
#1140915
12/22/11 11:34 AM
12/22/11 11:34 AM
moparbroz
California
Thanks for all the great information guys. I really appreciate it. I am going to tear everything down myself and inspect and retorque everything. I will use Johns crank as a replacement. I might as well do the cam too while I am at it.
Hebrews 11:1
Re: Crank is broken
[Re: Dodgem]
#1140916
12/22/11 11:42 AM
12/22/11 11:42 AM
moparbroz
California
Thanks too Barry for your generous offer!
Hebrews 11:1
Re: Crank is broken
[Re: moparbroz]
#1140921
12/22/11 03:35 PM
12/22/11 03:35 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
I have to ask, what engine hoist were you using and what was the failure on the hoist?
Re: Crank is broken
[Re: 6PakBee]
#1140922
12/22/11 09:48 PM
12/22/11 09:48 PM
moparbroz
California
I was usaing a friends. Smaller than what I have usually seen. Boom was out too far. No leg extensions.
Hebrews 11:1
