Crank is broken
#1140903
12/21/11 04:21 PM
12/21/11 04:21 PM
Posts: 339 California
moparbroz
California
On a cherry picker and down the 440 went. Landed on the crankshaft pully and broke the end of the crankshaft clean off. I am by far not a motor guru and I know that I need a new balanced crank and to balance I need to get a machine shop a piston and rod. Should I attempt this myself or just drop off my motor? I have a highly recommended motor guru who I can have do the job.
Hebrews 11:1
Re: Crank is broken
[Re: moparbroz]
#1140904
12/21/11 04:29 PM
12/21/11 04:29 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
UMMM,, WOW, I would definatly have that block checked for any cracks from the impact. Every main got a shock when that ol girl hit, and I mean a side shock, stressing the bolts, and the webbing of the block where a load like that was NEVER designed to hit it. Crazy how that broke. Glad you arent hurt, that could have gotten really nasty. Kasey
Re: Crank is broken
[Re: BigBlockMopar]
#1140908
12/21/11 09:55 PM
12/21/11 09:55 PM
Posts: 1,443 Maryland
Dads426
Maryland
I got a cherry cast crank that you can have if you want to pay shipping from the east coast. Should be able to find one out there for less than shipping though.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
Re: Crank is broken
[Re: Kern Dog]
#1140912
12/22/11 03:42 AM
12/22/11 03:42 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
If you look at the squareness of the counterweights you can tell it's cast, plus, a forged would likely not have broken like that. Regardless, I doubt it hurt the block, but I would replace at least that one upper main bearing on #1. If the motor is stock (factory rods and pistons) another stock cast crank that has never been molested should be close enough in balance. If it bothers you, definitely have the balance checked. Take the harmonic balancer and let them know the rear is also externally balanced. If you have a stick trans, take the flywheel, otherwise you're almost stuck buying a B&M external flexplate.
Re: Crank is broken
[Re: Dads426]
#1140913
12/22/11 11:26 AM
12/22/11 11:26 AM
moparbroz
California
John - Awesome offer! I really appreciate it. I will take you up on it if that is ok. My zip is 92867. Orange, CA. Thanks!
Hebrews 11:1
Re: Crank is broken
[Re: Kern Dog]
#1140914
12/22/11 11:28 AM
12/22/11 11:28 AM
moparbroz
California
Sorry Frankenduster. I didn't disapear, just had a bunch of stuff to do.
Hebrews 11:1
Re: Crank is broken
[Re: dodgeboy11]
#1140915
12/22/11 11:34 AM
12/22/11 11:34 AM
moparbroz
California
Thanks for all the great information guys. I really appreciate it. I am going to tear everything down myself and inspect and retorque everything. I will use Johns crank as a replacement. I might as well do the cam too while I am at it.
Hebrews 11:1
Re: Crank is broken
[Re: Dodgem]
#1140916
12/22/11 11:42 AM
12/22/11 11:42 AM
moparbroz
California
Thanks too Barry for your generous offer!
Hebrews 11:1
Re: Crank is broken
[Re: moparbroz]
#1140921
12/22/11 03:35 PM
12/22/11 03:35 PM
Posts: 10,717 North Dakota
6PakBee
North Dakota
I have to ask, what engine hoist were you using and what was the failure on the hoist?
Re: Crank is broken
[Re: 6PakBee]
#1140922
12/22/11 09:48 PM
12/22/11 09:48 PM
moparbroz
California
I was usaing a friends. Smaller than what I have usually seen. Boom was out too far. No leg extensions.
Hebrews 11:1
Re: Crank is broken
[Re: Dads426]
#1140925
12/23/11 01:26 AM
12/23/11 01:26 AM
moparbroz
California
I can give you a ups shipping label from my wife's work. All I need is weight and box size. I can email or fax it to you.
Hebrews 11:1
Re: Crank is broken
[Re: Dads426]
#1140926
01/03/12 03:56 PM
01/03/12 03:56 PM
moparbroz
California
Jon came through with the crank! I would polish and install it asap except that unfortunately my wife went into the hospital with a very serious Pulmonmary decease last Tuesday and I have been with here there 99% of the time. Priorities. Thanks all especially to Jon!
Hebrews 11:1
Re: Crank is broken
[Re: Dads426]
#1140929
02/05/12 02:13 PM
02/05/12 02:13 PM
moparbroz
California
Unfortunately my wife had a heart attack on 12/27 and I put EVERYTHING on the back burner to care for her. God is awesome and she is slowly recovering so I have had some time yesterday to work on the crank swap. Jon’s was right. The crank he gave me is “CHERRY!” I can’t thank him enough. Pulling the last two main caps off today and will drop off the crank that Jon gave me, a piston, rod and balancer to “Russ’s Muscle” on Monday or Tuesday so the crank can be balanced. Should have her all back together in just a short while. Wanted to share an update and also give Jon (dads426) another shout out for the ultimate mopar bro gesture. Quote:
Not a problem. That's what this boards all about. Plus, I get to clean out my garage since I never throw anything away...
We'll see if Steve wants to pay shipping from the right coast.
Hebrews 11:1
