I had my Halibrand wheels milled.... #1140571
12/21/11 10:45 AM
12/21/11 10:45 AM
Kentucky
Flipper1938 Offline OP
Kentucky
...to work with stock Dodge Dakota wheel studs. (The 41 Dodge is going on a Dakota frame)
When I bought them (used) they came with centers that were 1.5" thick. There were no threads on the wheel stud beyond the hole in the wheel. They were only held on by the threads in the lug nut shank....nothing in the head of the lug nut.
I fixed that. I had pockets milled into the wheels to get full thread engagement. I now have little windows where the lug holes hit the center hole, but that is minor compared to failing lug nuts at highway speeds.
before
after
with nuts
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140572
12/21/11 11:45 AM
12/21/11 11:45 AM
moparx Offline
moparx  Offline
just a thought.... you mite want to consider a way to radius the top & bottom of the "windows" that were created by the pocket milling into the hub center area to prevent stress cracks. not sure that mite happen, but it's possible.
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140573
12/21/11 01:09 PM
12/21/11 01:09 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Can I ask where you found the six lug Halibrands?
Re: I had my Halibrand wheels milled.... [Re: bohmer2] #1140574
12/21/11 02:00 PM
12/21/11 02:00 PM
Kentucky
Kentucky
Ebay ...5 years ago (dang time flies) Shortly after I picked up the 41 Dodge (that I still haven't built)
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140575
12/21/11 08:47 PM
12/21/11 08:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think longer studs might have been a solution?
Don't be the exception.
Re: I had my Halibrand wheels milled.... [Re: Supercuda] #1140576
12/21/11 10:39 PM
12/21/11 10:39 PM
Kentucky
Kentucky
I never could find a long stud that fit the front of a 2001 dakota
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140577
12/22/11 12:51 AM
12/22/11 12:51 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.summitracing.com/parts/ARP-100-7706/
Re: I had my Halibrand wheels milled.... [Re: Supercuda] #1140578
12/22/11 01:03 AM
12/22/11 01:03 AM
CrazyD Offline
CrazyD  Offline
Maybe its just the angle of the pictures, but it looks like a lot of material was removed from the hub sidewalls and lug holes. I'd be concerned with loss of rigidity in the mounting area.
Re: I had my Halibrand wheels milled.... [Re: CrazyD] #1140579
12/22/11 01:19 AM
12/22/11 01:19 AM
Kentucky
Kentucky
There is still .800" of unmolested metal under the lug nut washer.
Re: I had my Halibrand wheels milled.... [Re: CrazyD] #1140580
12/27/11 11:05 PM
12/27/11 11:05 PM
ct USA
anhourlater Offline
anhourlater  Offline
ct USA
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140581
01/01/12 03:19 AM
01/01/12 03:19 AM
Kentucky
Kentucky
With the knock-off center caps
and the tires that will go on them. 215/50/17 front and 285/60/18 rear. The Dodge should have a pretty good rake to it!
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140582
01/01/12 09:06 PM
01/01/12 09:06 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
I like
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140583
01/16/12 12:37 AM
01/16/12 12:37 AM
Kentucky
Kentucky
The lugs fit like I planned.
The socket just barely has clearance
With tires
Re: I had my Halibrand wheels milled.... [Re: Flipper1938] #1140584
01/17/12 06:08 PM
01/17/12 06:08 PM
dogdays Offline
dogdays  Offline
I doubt you compromised the strength at all.
Looks Great!
R.
